Power Query Load is Stuck at Creating connection in model - Loading Data from Oracle DB
- Anonymous4 years ago
A similar issue has been reported internally, ICM: 263271425
And this is the latest updated information from PG:
We have a fix for this internally, which will be released in the November version of Power BI Desktop.
Best regards
Paul Zheng _ Community Support Team
This is what I did to solve the issue.
1. Went into the temp files under App data -> Users -> Local & Local low & Roaming profiles, deleted all the file in there.
2. Uninstalled the entire version of the power BI desktop, Downloaded the current version available.
3. Opened the PBIX file and then enabled the Data Preview options Downloads and the report's been running faster than expected 🙂
