Anonymous's avatar
5 years ago
Power Query Editor doesn't load even small tables and occupies ressources
Hello everyone,   we're having massive performance problems with the Power Query Editor. It was always a bit slow to perform some tasks like adding a new column, but it worked until yesterday. The ...
    5 years ago
    Hi everyone,
    sorry for the late reply, i was hesitating to post my code because of Colleagues Names in the calculated Columns. We fixed the issue by ourselves, by building again.
    Solution:
    Many of our Tables had many Steps (30+): So we grouped them. (I think that was the biggest factor. Now each function has only to be called once?)
    Much data was unnessecarily loaded: We already filtered in the Dataflow and used the Query editor only for modeling
    If you come upon this on your search i can only emphasize on grouping your steps in the Query editor and using the reference option if possible when "copying" a table. And be careful on deleting steps that later steps could rely on. Guy in a Cube also has some helpful content regarding performance issues.
    Thanks everyone for all your help,
    Best regards
