Power BI -> Dataverse Connection (Column connection reference in Canvas App)
- 1 year ago
Hi Yaybaa ,
The JSON in connectionreference is expected – Dataverse stores it that way. Don’t parse it manually.
Instead, use the proper system tables:
connectionreferences > join with canvasapps to get friendly connector names.
environmentvariabledefinition / environmentvariablevalue > to list environment variables.
workflow (flows) + solutioncomponent > to see flows linked to the same app/solution.
This way you can map Canvas App > Connection References > Env Vars > Flows without breaking down JSON yourself.
Hi Yaybaa ,
