Open Side Menu
Skip to contentBrand Logo
Forums
Inspiration
Ideas
Communities
Blogs
Learning
Support
RegisterSign In
  1. Microsoft Fabric Community
  2. Power BI forums
  3. Power Query
Oussama's avatar
Oussama
10 years ago
Power BI embedded with SSAS directe connection
Hi, I followed these steps here: https://azure.microsoft.com/en-us/documentation/articles/power-bi-embedded-get-started-sample/ To embed a report with directe connection to an SSAS cube.   1) I s...
Need Help
mikes2nd's avatar
mikes2nd
10 years ago
Take a look at this.
https://github.com/Azure/azure-content/blob/master/articles/power-bi-embedded/power-bi-embedded-app-token-flow.md
Once you get a grasp of that, look at mapping Azure AD, at the top the author states
"This design does not require your app to use Azure Active Directory for user authentication and authorization, although you can do this."
Oussama's avatar
Oussama
10 years ago
Hi dear,
Could you please be more clear. I am not a .NET developer, I just want to use the sample on th GitHub.
My report work fine when uploaded to Power Bi Service.
I guess that the Patch to update the datasource is already applied on the Sample code :
// Update the datasource with the specified credentials
await client.Gateways.PatchDatasourceAsync(workspaceCollectionName, workspaceId, datasources.Value[datasources.Value.Count - 1].GatewayId, datasources.Value[datasources.Value.Count - 1].Id, delta);
My concerne is with the parameter I should use:
// Reset your connection credentials
                var delta = new GatewayDatasource
                    CredentialType = "Basic",
                    BasicCredentials = new BasicCredentials
                        Username = username,
                        Password = password
I guess that user name and password are those used for my datasource on the Gateway.
The VS debugger shows a null value for datasources variable.
Should I enter a connection string ?
  • mikes2nd's avatar
    mikes2nd
    10 years ago
    https://powerbi.microsoft.com/en-us/blog/tech-tip-thursday-authentication-with-analysis-services-live-connections/
    Take a look, it
    • Mohamed's avatar
      Mohamed
      Advocate I
      10 years ago
      Thank you Mikes, but will that work in Power BI Embedded?
      • shay_cullen's avatar
        shay_cullen
        9 years ago
        Did this ever get solved?
Related content
  • RLS implementation under direct Lake connectivity
    5 months ago
    ankurarora1418
  • Power BI Direct Query (Live connection)
    6 months ago
    jishnubhattacha
  • Power BI Direct Connection to SAP HANA Production Database
    3 months ago
    SantaT
  • PBI Embedded
    1 year ago
    poojithap
  • Private Endpoint support for direct EventHub → EventHouse connection
    10 months ago
    PiotrJakub
  • © 2026 Microsoft
  • Manage cookies
  • Privacy & cookies
  • Terms of use
  • Trademarks
Your Privacy Choices Consumer Health Privacy
