Open Side Menu
Skip to contentBrand Logo
Forums
Inspiration
Ideas
Communities
Blogs
Learning
Support
RegisterSign In
  1. Microsoft Fabric Community
  2. Power BI forums
  3. Power Query
Oussama's avatar
Oussama
10 years ago
Power BI embedded with SSAS directe connection
I followed these steps here: https://azure.microsoft.com/en-us/documentation/articles/power-bi-embedded-get-started-sample/
To embed a report with directe connection to an SSAS cube.
1) I successfuly create a workspaceId on the workspace collection (step 5)
2) I successfuly import a pbix file to the workspace (step 6)
3) I stuck on step 7, to update the dataset of the pbix file already uploaded
         Witch value of parametres should I use: username, password, connection string ?
         Where can I found the connection string of the PBI with SSAS ?
Thx.
Need Help
  • Jaredk24's avatar
    Jaredk24
    9 years ago
    Has anyone successfully published a report using SSAS and embedded?
    We can not find any information on how this should be done and all the responses so for from MS folks are for SQL DW direct connections.  Which does work but is very very different then authorizing against SSAS.
  • mikes2nd's avatar
    mikes2nd
    10 years ago
    Take a look at this.
    https://github.com/Azure/azure-content/blob/master/articles/power-bi-embedded/power-bi-embedded-app-token-flow.md
    Once you get a grasp of that, look at mapping Azure AD, at the top the author states
    "This design does not require your app to use Azure Active Directory for user authentication and authorization, although you can do this."
    • Oussama's avatar
      Oussama
      10 years ago
      Hi dear,
      Could you please be more clear. I am not a .NET developer, I just want to use the sample on th GitHub.
      My report work fine when uploaded to Power Bi Service.
      I guess that the Patch to update the datasource is already applied on the Sample code :
      // Update the datasource with the specified credentials
      await client.Gateways.PatchDatasourceAsync(workspaceCollectionName, workspaceId, datasources.Value[datasources.Value.Count - 1].GatewayId, datasources.Value[datasources.Value.Count - 1].Id, delta);
      My concerne is with the parameter I should use:
      // Reset your connection credentials
                      var delta = new GatewayDatasource
                          CredentialType = "Basic",
                          BasicCredentials = new BasicCredentials
                              Username = username,
                              Password = password
      I guess that user name and password are those used for my datasource on the Gateway.
      The VS debugger shows a null value for datasources variable.
      Should I enter a connection string ?
      • mikes2nd's avatar
        mikes2nd
        10 years ago
        https://powerbi.microsoft.com/en-us/blog/tech-tip-thursday-authentication-with-analysis-services-live-connections/
        Take a look, it
    9 years ago
    Hello, do we have any news from this?
    thanks,
      9 years ago
      any ideas how to overcome this thing? direct query has serious performance issues.
Related content
  • RLS implementation under direct Lake connectivity
    5 months ago
    ankurarora1418
  • Power BI Direct Query (Live connection)
    6 months ago
    jishnubhattacha
  • Power BI Direct Connection to SAP HANA Production Database
    3 months ago
    SantaT
  • PBI Embedded
    1 year ago
    poojithap
  • Private Endpoint support for direct EventHub → EventHouse connection
    11 months ago
    PiotrJakub
  • © 2026 Microsoft
  • Manage cookies
  • Privacy & cookies
  • Terms of use
  • Trademarks
Your Privacy Choices Consumer Health Privacy
