aliciaortega93's avatar
aliciaortega93
3 months ago
Power BI downloaded PBIX does not contain Power Query queries
Hi everyone,
I am having a very confusing issue with a Power BI report and I would appreciate some guidance.
Background
I inherited a Power BI report created by another developer.
The report is published in Power BI Service and uses several Azure Functions as data sources (REST APIs returning JSON).
Current sources include endpoints like:
  • /api/get_jira_epics
  • /api/get_jira_tasks
  • /api/get_jira_sprints
The report itself works correctly in Power BI Service.
Problem 1 – Downloaded PBIX has no queries
When I download the report from Power BI Service as:
“A copy of your report and data (.pbix)”
and open it in Power BI Desktop:
  • the report visuals appear correctly
  • the dataset exists
  • BUT when I go to:
Transform Data
the Power Query editor is completely empty.
No queries are visible at all.
So I cannot see or edit the original queries created by the previous developer.
This makes me think the report may be:
  • connected to a semantic model
  • or partially live-connected
but I am not fully sure.
Problem 2 – Adding a new Azure Function breaks the report
I created a new Azure Function endpoint:
/api/get_pmo_weekly
The function works correctly and returns valid JSON data.
When I add it in Power BI Desktop using:
Get Data → Web
the table loads correctly and I can preview the data in Power Query.
However, after:
Close & Apply
the entire report breaks.
All visuals start showing errors such as:
There was a problem with one or more fields
or:
The column 'CW_Tasks_Expanded[Week Start]' either doesn't exist
or:
Error fetching data for this visual
It looks like:
  • existing tables disappear
  • relationships break
  • measures become invalid
  • old visuals lose references
even though I only added one new Web source.
Additional context
The report uses:
  • Azure Functions (REST APIs)
  • MySQL Azure database
  • multiple DAX measures
  • custom visuals
  • slicers based on week ranges
My goal was simply:
  1. add a new table (PMO_Weekly)
  2. keep all existing tables intact
  3. create new visuals/measures using the new weekly data
But adding the new source seems to destabilize the whole model.
Questions
  1. Why are the original Power Query queries not visible in the downloaded PBIX?
  2. Is this behavior expected for reports connected to semantic models/thin reports?
  3. Why would adding a single new Web source cause existing tables/measures/visuals to disappear or fail?
  4. What is the correct approach to extend this kind of report architecture?
Any help would be greatly appreciated.
  • Along with the great suggestions from MFelix  and tayloramy , you can use the TMDL view in Desktop to see which connections your model is making.
    An example of what you may see...
  • Hi aliciaortega93 ,
    This can be because of the type of connection that the report uses check on the bottom rigth corner of your model what is the type of connection, Live connection, Direct Query, Import.
    That will allow to pin point the question.
  • Hi aliciaortega93
    If you open the report in desktop, then click the dropdown right beneath the transform data button in the ribbon, and click data source settings, what do you see in there?
    As MFelix mentioned, nothing being in power query implies that the model is using direct query connections and not import mode.
    • aliciaortega93's avatar
      aliciaortega93
      Thank you for your reply! When I click on that, I see the following:
      The last one, get_pmo_weekly is the new one I'm trying to use in the data.
