Power BI Embed Code Issue with MS Dynamics Direct Query
We have an MS Dynamics environment from which I pull data using Direct Query. I have created a report with this data. I want to publish this report on the web. I have configured the publish to web and other settings in the Admin Center. However, I still cannot generate an embed code. For reports I create with Excel-sourced data, I can get embed codes. Can you help me with this issue? How can I resolve this problem? I added a screenshot . I pushed the Publish button dont be anything.
Power Bı
Hi rumeysacoskun ,
That is one of the limitations for publish to web you cannot use Direct Query connection, amongst other type of connections. It is related with security questions since has the warning message the report data can be fully accesible
- MFelix
Hi rumeysacoskun ,
- AnonymousNot applicable
Hi rumeysacoskun,
Thanks for reaching out to the Microsoft fabric community forum. The behavior you describe in screenshot is expected. As already mentioned by MFelix, publish to web doesn’t support reports that use DirectQuery, because Publish to web makes the report and its underlying data publicly available and DirectQuery models query live data. That combination isn’t allowed. See Microsoft’s Publish to web docs for the limitation. Kindly go through the documentation link provided to get a better understanding of the limitation.
I would also take a moment to thank MFelix, for actively participating in the community forum and for the solutions you’ve been sharing in the community forum. Your contributions make a real difference.
If I misunderstand your needs or you still have problems on it, please feel free to let us know.
Hammad.- AnonymousNot applicable
Hi rumeysacoskun,
As we haven’t heard back from you, so just following up to our previous message. I'd like to confirm if you've successfully resolved this issue or if you need further help.
If yes, you are welcome to share your workaround so that other users can benefit as well. And if you're still looking for guidance, feel free to give us an update, we’re here for you.
Hammad.
Hello rumeysacoskun,
I hope the information provided above assists you in resolving the issue. If you have any additional questions or concerns, please do not hesitate to contact us. We are here to support you and will be happy to help with any further assistance you may need.
Community Support Team.
