Get Fabric Certified for FREE during Fabric Data Days. Don't miss your chance! Learn more
DaveW72579
Please help sort out a problem with using "Duration" calculation
I can not find a cylical issue, but I am very new to the community. Thank you
Ah, I couldn't see the last bit of code in your original screenshot.
You need to delete this last bit too:
Pete
Proud to be a Datanaut!
DaveW72579
Thank you Pete
Here is the result
Pete
BA_Pete
Hi @DaveW72579 ,
Delete everything highlighted here:
You only need to enter the column calculation into the Add Column dialog - it will generate the rest of the necessary code for you.
Pete
