Jruiz218
6 years agoFrequent Visitor
Please Help!!! Grand Total Calculating Wrong Average - Power Pivot
Hello! Im migrating a report from regular Excel tables/Pivots over to PowerPivot, currently this is my scenario: In the old version of the report my source data came in the following format: ...
- 6 years ago
Hi Jruiz218 ,
Based on the data you have send out you need to do the following:
- Create a measure with the Average of the Hours Handled (this will be used as an intermediat step)
Measure_Average_Hour_Handle =AVERAGE('Dummy Data'[Hours Handled])- Add another measure:
Average_Hours_Handled = IF ( HASONEVALUE ( 'Calendar Resolved'[Date] ); [Measure_Average_Hour_Handle]; AVERAGEX ( SUMMARIZE ( 'Calendar Resolved'; 'Calendar Resolved'[Date]; 'Calendar Resolved'[Week Number] ); [Measure_Average_Hour_Handle] ) )Should work as expected.
MFelix
6 years agoSuper User
Hi Jruiz218 ,
Try the following calculation below.
var Time_Opened = IF(Table[Resolved] - Table[Created] <0 , 0 , Table[Resolved] - Table[Created])
Return
IF(HASONEVALUE(Calendar[WEEKNUMBER]), Time_Opened,AVERAGEX(Calendar,Time_Opened) )
If this does not work can you share a mockup file please.
Jruiz218
I just sent you the link to the report via private message.
Thank you so much for taking a look at it!
- MFelix6 years agoSuper User
Hi Jruiz218 ,
