Anonymous's avatar
2 years ago
Need help with using custom query to bring in data from Oracle Database
I am running this SQL query to bring in data from our Oracle Server, but I keep getting an error and I am not exactly sure why. The query runs fine in Toad.
SELECT v.*, COALESCE(e.INCIDENT_COUNT, 0) AS VENDOR_INCIDENT_COUNT
FROM ISAFETY_DBA.SAFETY_OPS_VENDORS v
LEFT JOIN (
SELECT VENDOR_NAME, COUNT(*) AS INCIDENT_COUNT
FROM ISAFETY_DBA.SAFETY_EVENT_HDR_VW
GROUP BY VENDOR_NAME
) e ON v.VENDOR_NAME = e.VENDOR_NAME;
I get error: Oracle: ORA-00933: SQL command not properly ended
Any help would be appreciated!
1 Reply
    Hi Anonymous ,
    This error typically occurs because you have a misspelling in your SQL statement, unsupported syntax or clauses, or the string terminates prematurely, causing the rest of the string to be interpreted as a markup.
    Please ensure there's no semicolon (;) at the end of your query when running it in the problematic environment. Some SQL execution environments or connectors might not expect a semicolon.
    And you can try running a simplified version of your query to isolate the issue. Start with a basic SELECT statement from one table and gradually add complexity (e.g., joins, subqueries) until the error reappears.
    I've found some links for you that may be useful, so you can try reading through them to see if you can find a solution:
    ORA-00933 - Database Error Messages (oracle.com)
    oracle - SQL Error: ORA-00933: SQL command not properly ended - Stack Overflow
    www.howtosop.com
    Also ,sometimes the issue might not be with the query itself but with how the connection is configured or the permissions set up for the user executing the query. Ensure that the user has the necessary permissions to execute the types of commands in your query and that the connection to the Oracle server is correctly configured.
    Dino Tao
