Need help with power query
- 2 years ago
Hi testyuiiop,
v1 Group should be faster, but if you do not have many rows - you won't see the difference.
Result
v1 Group
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WclTSUTJUitWJVlJwAjKNIEwFZyDbGMpWcAFyTMAcR0Mk5YbI6g1RNBhCdMQCAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Name = _t, Rank = _t]), TrimmedText = Table.TransformColumns(Source,{{"Name", Text.Trim, type text}}), GroupedRows = Table.Group(TrimmedText, {"Rank"}, {{"All", each Table.ToColumns(Table.RemoveColumns(_, {"Rank"})), type table}}), Combined = Table.FromColumns(List.Combine(GroupedRows[All]), List.Transform(GroupedRows[Rank], Text.From)) in Combinedv2 Pivot
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WclTSUTJUitWJVlJwAjKNIEwFZyDbGMpWcAFyTMAcR0Mk5YbI6g1RNBhCdMQCAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Name = _t, Rank = _t]), TrimmedText = Table.TransformColumns(Source,{{"Name", Text.Trim, type text}}), PivotedColumn = Table.Pivot(Table.TransformColumnTypes(TrimmedText, {{"Rank", type text}}, "sk-SK"), List.Distinct(Table.TransformColumnTypes(TrimmedText, {{"Rank", type text}}, "sk-SK")[Rank]), "Rank", "Name", each _), Ad_FinalTable = Table.AddColumn(PivotedColumn, "FinalTable", each Table.FromColumns(Record.ToList(_), Table.ColumnNames(PivotedColumn)), type table), FinalTable = Ad_FinalTable{0}[FinalTable] in FinalTable
Thank you!!
Could you please help me in understanding how you have grouped the rows?
- dufoq32 years agoCommunity Champion
I've grouped by Rank. Inside [All] column you see:
Table.ToColumns(Table.RemoveColumns(_, {"Rank"}))which means:
- delete [Rank] column - Table.RemoveColumns
- transform table to list of lists where every row (list) represent one column - Table.ToColumns
At last step Combined I'm combining all list from GropedRows[All] Column to this where every list represents one column.
To create table from columns I'm using Table.FromColumns function with 2nd parameter column names --> List.Transform(GroupedRows[Rank], Text.From) - but just for sure I'm transforming column names --> GropedRows[Rank] column to text (because you can have it at that step as number and it would finished as an error).
My english is not that good as my power query - sorry for that in advance.
- testyuiiop2 years agoHelper I
Thanks you so much for the explantation.
