testyuiiop
2 years agoHelper I
Need help with power query
I'm working on hierarchial data.
My data is like below, rank represents the hierachy level.
and I want the expected outpout like below:
How I can achieve this in power query?
and I want my
Hi testyuiiop,
v1 Group should be faster, but if you do not have many rows - you won't see the difference.
Result
v1 Group
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WclTSUTJUitWJVlJwAjKNIEwFZyDbGMpWcAFyTMAcR0Mk5YbI6g1RNBhCdMQCAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Name = _t, Rank = _t]), TrimmedText = Table.TransformColumns(Source,{{"Name", Text.Trim, type text}}), GroupedRows = Table.Group(TrimmedText, {"Rank"}, {{"All", each Table.ToColumns(Table.RemoveColumns(_, {"Rank"})), type table}}), Combined = Table.FromColumns(List.Combine(GroupedRows[All]), List.Transform(GroupedRows[Rank], Text.From)) in Combinedv2 Pivot
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WclTSUTJUitWJVlJwAjKNIEwFZyDbGMpWcAFyTMAcR0Mk5YbI6g1RNBhCdMQCAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Name = _t, Rank = _t]), TrimmedText = Table.TransformColumns(Source,{{"Name", Text.Trim, type text}}), PivotedColumn = Table.Pivot(Table.TransformColumnTypes(TrimmedText, {{"Rank", type text}}, "sk-SK"), List.Distinct(Table.TransformColumnTypes(TrimmedText, {{"Rank", type text}}, "sk-SK")[Rank]), "Rank", "Name", each _), Ad_FinalTable = Table.AddColumn(PivotedColumn, "FinalTable", each Table.FromColumns(Record.ToList(_), Table.ColumnNames(PivotedColumn)), type table), FinalTable = Ad_FinalTable{0}[FinalTable] in FinalTable
- dufoq3Community Champion
Hi testyuiiop,
Result
v1 Group
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WclTSUTJUitWJVlJwAjKNIEwFZyDbGMpWcAFyTMAcR0Mk5YbI6g1RNBhCdMQCAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Name = _t, Rank = _t]), TrimmedText = Table.TransformColumns(Source,{{"Name", Text.Trim, type text}}), PivotedColumn = Table.Pivot(Table.TransformColumnTypes(TrimmedText, {{"Rank", type text}}, "sk-SK"), List.Distinct(Table.TransformColumnTypes(TrimmedText, {{"Rank", type text}}, "sk-SK")[Rank]), "Rank", "Name", each _), Ad_FinalTable = Table.AddColumn(PivotedColumn, "FinalTable", each Table.FromColumns(Record.ToList(_), Table.ColumnNames(PivotedColumn)), type table), FinalTable = Ad_FinalTable{0}[FinalTable] in FinalTable- testyuiiopHelper I
Thank you!!
You're welcome. Few seconds ago I've added v2 into prev. post.
@Ibendlin Vijay_A_Verma dufoq3
