aravind2409
3 years agoNew Member
Need help with manually calculating difference between two percentage or numbers and cond. formattin
Hi All, I have a data like this. Need help with subtracting Jan - Feb and Feb - March like wise and show the difference. Kindly help this is bit urgent. Would be great if some one can help on thi...
mussaenda
3 years agoCommunity Champion
It was not indicated on your first post that you need the percentage value difference.
Anyway, i had no idea how the Total Resolved % is claculated.
but if this is what you want to achieve,
use the previousmonth function for the % and the subtract them
Resolved % LM =
CALCULATE(
[RESOLVED %],
PREVIOUSMONTH('Table (2)'[Date]),
REMOVEFILTERS('Table (2)'))
aravind2409
2 years agoNew Member
Thank you sir.
