aravind2409
2 years agoNew Member
Need help with manually calculating difference between two percentage or numbers and cond. formattin
Hi All, I have a data like this. Need help with subtracting Jan - Feb and Feb - March like wise and show the difference. Kindly help this is bit urgent. Would be great if some one can help on thi...
mussaenda
2 years agoCommunity Champion
Hi aravind2409 ,
"My requirement is in Jan percentage is 83.83 and Feb is 85.07 i want the difference between two (85.07-83.33)"
according to your requirement, test1 is correct, right? you just need to change the data type to %
