CBVC-HB's avatar
CBVC-HB
3 years ago
Need help transforming a spreadsheet how I want using power query so I can automate it
Hi Guys,
I have a csv in the below format (just a small excerpt, actually goes up to 30000 for 2nd row, after which it repeats with 36 on the first row and 5000 to 30000 on 2nd row):
 24
 5000  8000  10000
CAP CodeFinanceServiceTotalFinanceServiceTotalFinanceServiceTotal
A123456789
B111213141516171819
C212223242526272829
I want to put it into this format:
CAP CodeTermMileageFinanceServiceTotal
A245000123
A248000456
A2410000789
B245000111213
B248000141516
B2410000171819
C245000212223
C248000242526
C2410000272829
Having trouble doing this, it's feels like a transpose but with extra steps. Hope someone can point me in the right direction.
  • wdx223_Daniel's avatar
    wdx223_Daniel
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("nZA/C4MwEEe/SsjskDurtqMNdC60mziIOghFoUg/f+9FCnbp0OEX8ue9XC5N453PvB5scD/TZhtahBB2B8fvpYT9GifWVxeXYbSNyzR3c8/sNj5fU5rdl7V7/H1GgZqy9GDJLbRSWEpLxQstp0SeIUEFVoAFWsAFXhAEQzYlcnG6HUXzz18piqIoiqKoKe0b", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Column1 = _t, Column2 = _t, Column3 = _t, Column4 = _t, Column5 = _t, Column6 = _t, Column7 = _t, Column8 = _t, Column9 = _t, Column10 = _t]),
        Custom1 = let a=Table.ToColumns(Table.Skip(Source,2)),b=List.Split(List.Skip(a),3) in Table.FillDown(Table.Combine(List.Transform(List.Positions(b),each Table.PromoteHeaders(Table.FromColumns({a{0},{"Term",Source[Column2]{0}},{"Mileage",Record.ToList(Source{1}){_*3+1}}}&b{_})))),{"Term","Mileage"})
        Custom1
  • Hi
    Another solution
    Source = YourSource,
    Transpose = Table.Transpose(Source),
    FillDown = Table.FillDown(Transpose,{"Column1", "Column2"}),
    Headers = Table.PromoteHeaders(FillDown, [PromoteAllScalars=true]),
    ColumnNames = Table.RenameColumns(Headers,{{"Column1", "Term"}, {"Column2", "Mileage"}, {"CAP Code", "Code"}}),
    UnPivot = Table.UnpivotOtherColumns(ColumnNames, {"Term", "Mileage", "Code"}, "CAP Code", "Value"),
    Pivot = Table.Pivot(UnPivot, List.Distinct(UnPivot[#"Code"]), "Code", "Value")
    Pivot
    Stéphane
  • CBVC-HB's avatar
    CBVC-HB
    Is there any way of doing this through the GUI? I was working on it earlier and was able to change it to:
    CAP CodeTermMileageFinanceServiceTotalTermMileageFinanceServiceTotalTermMileageFinanceServiceTotal
    A2450001232480004562410000789
    B2450001112132480001415162410000171819
    C2450002122232480002425262410000272829
    So it's like I need column 7-11 to move onto a new row while keeping it's cap code on the first column, and doing it every 5 columns until the end.
