Need help to correct a syntax error in my power query formula
- Anonymous1 year ago
Thanks for the solution ZhangKun and jgeddes offered, and i want to offer some mroe information for user to refer to.
hello Anonymous , you can click the 'Accout Name' and 'Postcode' columns, then click merged columns in 'Add column' tab
Then select split them by using the space.
Output
Best Regards!
Yolo Zhu
Output
Best Regards!
Yolo Zhu
