Need help paging in my Power Query
I'm looking to implement paging in my Power Query. I'm currently querying a REST API, and have successfully built code to authenticate, query & transform the data. The API only returns a portion of the records, so I need a way to query the entire dataset.
I followed the Microsoft oData paging example, and successfully implemented it with their TripPin API: https://docs.microsoft.com/en-us/power-query/samples/trippin/5-paging/readme
This API uses the @odata.nextLink field in the body to page thru the data.
Here's an example: "@odata.nextLink": "https://services.odata.org/v4/TripPinService/People?%24skiptoken=8"
My API includes the next link field in the header to page thru the data.
Ref: https://developer.connectwise.com/Best_Practices/Manage_Pagination?mt-learningpath=manage
Here's an example: <https://staging.connectwisedev.com/v2017_3/apis/3.0/company/companies?pageSize=50&page=2>; rel="next", <https://staging.connectwisedev.com/v2017_3/apis/3.0/company/companies?pageSize=50&page=4>; rel="last"
My guess is that I have to extract the header from the Web.Content response, then look for rel="next".
I've been beating on this for a while, but not making any real progress. If someone else has accomplished this, I would appreciate the help.
Thank you for reading.
Please see this video for one way to accomplish this.
Power BI - Tales From The Front - REST APIs - YouTube
Pat
- mahoneypatMicrosoft Employee
Pat
- RobHess05Helper I
Love this solution. The each statement that allows me to loop thru multiple API calls is key.
Here's my code in case someone stumbles across this. I had to screen capture it from the video, and adjust to make my own 🙂BTG_ManageImplPage = (url as text) => let source = Json.Document(Web.Contents(url & "/count", [ Headers = DefaultRequestHeaders ])), count = (source[count]), pages = List.Numbers(0,count/PageSize, PageSize), #"Converted to Table" = Table.FromList(pages, Splitter.SplitByNothing(), null, null, ExtraValues.Error), #"Changed Type" = Table.TransformColumnTypes(#"Converted to Table",{{"Column1", type text}}), #"Added Custom" = Table.AddColumn( #"Changed Type", "Custom", each Json.Document(Web.Contents(url & "?pageSize=" & Number.ToText(PageSize) & "&page="&[Column1], [ Headers = DefaultRequestHeaders ]))), #"Expanded Custom" = Table.ExpandListColumn(#"Added Custom", "Custom"), in #"Expanded Custom";
