suparnababu8's avatar
suparnababu8
2 years ago
Need help on Pivot/Unpivot/Transpose in Power Query Editor
Hi @fabric_Community    I need a help from all of you. I have data like below mentioned image-1   Year Jan FEB MAR 2021 ABC DEF GHI ABC DEF GHI ABC DEF GHI L&T 5 5 ...
  • spinfuzer's avatar
    2 years ago
    Import Table into Power Query with no headers (headers should be Column1 to ColumnN).
    I did the replace value blanks to nulls because my data was blank instead of null.  You may not need to do that.
    Copy and paste the entire code into a blank query to see example.
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WikxNLFLSUfJKzAOSEOTm6gRn+zoGQdmxOtFKRgZGhkC2o5MzkHRxdQOS7h6eRImAtPvElBoYGJmFAIVMCWKQBtcQRyDbhCAGqXV2BJlrTBCD1Ho7gXxlRBCDzU0sSS0qyMzJAYeTIUEM0uMC8ag70R4lNRaMRmNhEMSC8WgsUDsWYgE=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Column1 = _t, Column2 = _t, Column3 = _t, Column4 = _t, Column5 = _t, Column6 = _t, Column7 = _t, Column8 = _t, Column9 = _t, Column10 = _t]),
        #"Replaced Value" = Table.ReplaceValue(#"Changed Type","",null,Replacer.ReplaceValue,{"Column2", "Column3", "Column4", "Column5", "Column6", "Column7", "Column8", "Column9", "Column10"}),
        #"Grouped Rows" = Table.Group(#"Replaced Value", {"Column1"},
                {"Rows",
                each let
                    tranpose_filldown = Table.FillDown(Table.Transpose(_),{"Column1"}),
                    merge_cols = Table.PromoteHeaders(Table.Transpose(Table.CombineColumns(tranpose_filldown,{"Column1","Column2"},Combiner.CombineTextByDelimiter(";"),"Merged"))),
                    unpivot = Table.UnpivotOtherColumns(merge_cols, {Table.ColumnNames(merge_cols){0}}, "Attribute", "Value"),
                    year = Text.AfterDelimiter(Table.ColumnNames(unpivot){0},";"),
                    add_year = Table.AddColumn(unpivot, "Year", each year),
                    split = Table.SplitColumn(add_year,"Attribute",Splitter.SplitTextByDelimiter(";")),
                    rename = Table.RenameColumns(
                        split,
                            {Table.ColumnNames(split){0}, "Column1"}
                    rename
            GroupKind.Local,
            (s,c) => Byte.From(c[Column1] = "Year")
        Combine = Table.Combine(#"Grouped Rows"[Rows])
        Combine
