Need help for generating raw wise difference from column using DAX or power query
- 1 year ago
Hi again
Please try ask the right question first time, because it is a bit annoying having to answer twice 😀😀😀
Click here to download a solution ftom one drive
This method will work for 25 machines or more
Please will you now click [thumbs up] and [accept solutoon button]. Thank you !
How it works ...
For the date correctly
Select the Date and Shift columns, then Transform> Unpiciot>Unpivot other columns
Sort by Machine, Date and Shift
Add an index column from 0 incrementing by 1
Get the machine and reading for the previous row
Change reading to numeric data types
and add a conditional columnRenove the unneeded columns and change the usage ro a numeric data type
Draw your graph
Hi again
How it works ...
Draw your graph
