Need help for generating raw wise difference from column using DAX or power query
- 1 year ago
Hi again
Please try ask the right question first time, because it is a bit annoying having to answer twice 😀😀😀
Click here to download a solution ftom one drive
This method will work for 25 machines or more
Please will you now click [thumbs up] and [accept solutoon button]. Thank you !
How it works ...
For the date correctly
Select the Date and Shift columns, then Transform> Unpiciot>Unpivot other columns
Sort by Machine, Date and Shift
Add an index column from 0 incrementing by 1
Get the machine and reading for the previous row
Change reading to numeric data types
and add a conditional columnRenove the unneeded columns and change the usage ro a numeric data type
Draw your graph
Hey Nicks612 ,
To calculate the difference in readings (Machine A and Machine B) shift-wise in Power BI using DAX and Power Query, here's a detailed breakdown for both approaches.
Power Query Steps
You can sort the data and use the Index method to calculate the difference:
Sort the table:
Sort by Date (ascending), then Shift (custom order: 1st Shift, 2nd Shift, 3rd Shift).
Add Index Column:
Add an Index column starting from 0.
Duplicate the table:
Right-click the query and Duplicate.
Rename duplicated columns:
Rename Machine A to Prev Machine A, Machine B to Prev Machine B, and Index to Prev Index.
Merge Queries:
Merge the original table with the duplicated one using:
Index = Prev Index + 1 (join on: Index from original and Prev Index from duplicate).
Expand columns:
Expand Prev Machine A and Prev Machine B.
Add Difference columns:
Difference A = [Machine A] - [Prev Machine A] Difference B = [Machine B] - [Prev Machine B]
If you found this solution helpful, please consider accepting it and giving it a kudos (Like) it’s greatly appreciated and helps others find the solution more easily.
Nasif Azam
- Nicks6121 year agoHelper I
Hi Nasif_Azam & speedramps ,
Thank you for the prompt response. I have tried it and it worked well. Both of you have a similar kind of solution. May many thanks to both of you!
However, I want to know what if there are more than 25 columns and we need this difference for all these columns? It will be tedious to add formula and column for that type of data. So can you please suggest any alternate solution for multiple columns in terms of measure or something?
Thanks in Advance!
- Nasif_Azam1 year agoSuper User
Hey Nicks612 ,
Glad to hear it worked! And that’s a great follow-up question regarding handling differences across many columns. If you’re dealing with 25+ columns, creating individual formulas for each can be tedious and error-prone. While DAX is powerful for dynamic measures, it isn’t ideal for row-wise comparisons across multiple columns. Instead, I’d suggest sticking with Power Query for scalability.
Power Query Pattern
You can automate the difference calculation across all relevant numeric columns using List.Transform and Record.TransformFields.
Sort your data by Date & Shift.
Add an Index Column (Index).
Duplicate the table and shift the index (PrevIndex = Index + 1).
Merge on Index and PrevIndex.
In the Merge step, after expanding the previous row's values:
Create a list of target columns (e.g., {"Machine A", "Machine B", ..., "Machine Z"})
Then dynamically compute differences:
let columnsToCompare = {"Machine A", "Machine B", "Machine C", ...}, AddDifferences = Table.TransformColumns( MergedTable, List.Transform(columnsToCompare, each { "Diff " & _, each Record.Field(_, _) - Record.Field(_, "Prev." & _), type number }) ) in AddDifferencesThis will create Diff Machine A, Diff Machine B, etc. for all desired columns without hardcoding each formula.
When creating your line chart combine Date + Shift into a single column for a cleaner X-axis. Like:
[Date] & " - " & [Shift]
Nasif Azam- Nicks6121 year agoHelper I
Hi @Nasif_Azam ,
Thank you so much for guidance and quick response. (Just for your information - I don't know much about M code so ignor silly mistakes I did when I followed these steps)
What I have done first is - merge two tables as a new and then expand the remaining columns as shown in below M code.
Source = Table.NestedJoin(#"Raw Data", {"Index"}, #"Raw Data Prev", {"Index"}, "Raw Data Prev", JoinKind.LeftOuter),
#"Expanded Raw Data Prev" = Table.ExpandTableColumn(Source, "Raw Data Prev", {"MAIN TR Power Reding ", "Bus Trunk -1 Meter reading", "Bus Trunk -6 Meter Reading", "Bus Trunk -2 Meter Reading", "Bus Trunk -4 Meter Reading", "Bus Trunk -3 Meter Reading", "6F2 Meter Reding", "Bus Trunk -5 Meter Reading", "Bus Trunk -9 Meter Reading", "Bus Trunk -10 Meter Reading", "Logistic Meter Reading", "Fan FDB Meter Reading", "Office + Canteen Meter Reading#(lf)", "ELDB Meter Reading", "Bus Trunk -7 Meter Reading", "8F4 Reading", "Main PDB Meter Reading", "U321 PDB Meter Reading (J3-601)", "PDB - 4 Meter Reading", "W601 Assembly Meter Reading"}, {"Raw Data Prev.MAIN TR Power Reding ", "Raw Data Prev.Bus Trunk -1 Meter reading", "Raw Data Prev.Bus Trunk -6 Meter Reading", "Raw Data Prev.Bus Trunk -2 Meter Reading", "Raw Data Prev.Bus Trunk -4 Meter Reading", "Raw Data Prev.Bus Trunk -3 Meter Reading", "Raw Data Prev.6F2 Meter Reding", "Raw Data Prev.Bus Trunk -5 Meter Reading", "Raw Data Prev.Bus Trunk -9 Meter Reading", "Raw Data Prev.Bus Trunk -10 Meter Reading", "Raw Data Prev.Logistic Meter Reading", "Raw Data Prev.Fan FDB Meter Reading", "Raw Data Prev.Office + Canteen Meter Reading#(lf)", "Raw Data Prev.ELDB Meter Reading", "Raw Data Prev.Bus Trunk -7 Meter Reading", "Raw Data Prev.8F4 Reading", "Raw Data Prev.Main PDB Meter Reading", "Raw Data Prev.U321 PDB Meter Reading (J3-601)", "Raw Data Prev.PDB - 4 Meter Reading", "Raw Data Prev.W601 Assembly Meter Reading"})
#"Expanded Raw Data Prev"After that, I have replace the above code with your code as you suggested and end up with the following error -
M code for this is -
columnsToCompare = {{"MAIN TR Power Reding ", "Bus Trunk -1 Meter reading", "Bus Trunk -6 Meter Reading", "Bus Trunk -2 Meter Reading", "Bus Trunk -4 Meter Reading", "Bus Trunk -3 Meter Reading", "6F2 Meter Reding", "Bus Trunk -5 Meter Reading", "Bus Trunk -9 Meter Reading", "Bus Trunk -10 Meter Reading", "Logistic Meter Reading", "Fan FDB Meter Reading", "Office + Canteen Meter Reading#(lf)", "ELDB Meter Reading", "Bus Trunk -7 Meter Reading", "8F4 Reading", "Main PDB Meter Reading", "U321 PDB Meter Reading (J3-601)", "PDB - 4 Meter Reading", "W601 Assembly Meter Reading"}, {"Raw Data Prev.MAIN TR Power Reding ", "Raw Data Prev.Bus Trunk -1 Meter reading", "Raw Data Prev.Bus Trunk -6 Meter Reading", "Raw Data Prev.Bus Trunk -2 Meter Reading", "Raw Data Prev.Bus Trunk -4 Meter Reading", "Raw Data Prev.Bus Trunk -3 Meter Reading", "Raw Data Prev.6F2 Meter Reding", "Raw Data Prev.Bus Trunk -5 Meter Reading", "Raw Data Prev.Bus Trunk -9 Meter Reading", "Raw Data Prev.Bus Trunk -10 Meter Reading", "Raw Data Prev.Logistic Meter Reading", "Raw Data Prev.Fan FDB Meter Reading", "Raw Data Prev.Office + Canteen Meter Reading#(lf)", "Raw Data Prev.ELDB Meter Reading", "Raw Data Prev.Bus Trunk -7 Meter Reading", "Raw Data Prev.8F4 Reading", "Raw Data Prev.Main PDB Meter Reading", "Raw Data Prev.U321 PDB Meter Reading (J3-601)", "Raw Data Prev.PDB - 4 Meter Reading", "Raw Data Prev.W601 Assembly Meter Reading"}},
Merge1,
"Diff " & _,
type number
AddDifferencesCan you please explain why I'm getting this error and suggest a solution?
Thanks in Advance!
- ronrsnfld1 year agoSuper User
This modification of my algorithm shows a method of handling multiple columns without having to hard code them.
It uses your existing data sample, which shows that the columns to be processed are all of the columns except for the first two.
It also uses a custom function to set the data types of the resultant table.
Again, paste the code into the Advanced Editor and read the comments to understand how it works
Main Code
let //change next line to reflect actual data source Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("bdE9CsMwDAXgq5TMLViS9XeOjiFbKe3Soc39qbCSkOCABw3+ePLzOA58wzgFebgO8Jsv99f7OceMUiuwxyRuphCDFnfDYbo2JavCz2Ov1MCacmBrqqB4p+i7VwykmgqrpyIpq9LzLFZjTqWiqUytU8csAW4qLhfMDQFo29DO2xASWiIAKRVS7bI6pYsizFCotXZZx3eJGi3VcUQ0JSKdOr5LQaCkij9IZba14ecbKinLWl2uCu7RxvQH", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Date = _t, Shift = _t, #"Machine A" = _t, #"Machine B" = _t, #"Machine C" = _t]), //Written so as not to require listing all the column names //Assumes Column one = Date; Column 2=Shift, and the rest are the columns to be processed colNames=Table.ColumnNames(Source), colTypes=List.Zip({List.Skip(colNames,2), List.Repeat({Int64.Type}, Table.ColumnCount(Source)-2)}), #"Changed Type" = Table.TransformColumnTypes(Source,{ {"Date", type date}, {"Shift", type text}} & colTypes), //In your sample data, the columns to process start with column three. //this line may need to be changed if not the case in your actual data #"Cols to Process" = List.Skip(colNames,2), //Create new column names by prefacing the processed columns with "Diff ". //Other algorithms could be used #"New Col Names" = List.Transform(#"Cols to Process", each "Diff " & _), //Create lists of differences for each processed column #"Compute Differences" = List.Accumulate( #"Cols to Process", {}, (s,cur)=> s & {[a=Table.Column(#"Changed Type",cur), b=List.Skip(a), c=List.Zip({a,b}), d=List.Transform(c, each _{1} - _{0}) ][d]}), //Create the "type table" line using a custom function #"Table Types" = [a=Table.ColumnNames(#"Changed Type"), b=#"New Col Names", c=a & b, d={type date, type text} & List.Repeat({Int64.Type}, List.Count(#"Cols to Process")+ List.Count(#"New Col Names")), e=fnRecordTypes(c,d)][e], //Combine the existing and new columns #"Combine Columns" = Table.FromColumns( List.FirstN(Table.ToColumns(#"Changed Type"),2+List.Count(#"Cols to Process")) & #"Compute Differences", type table #"Table Types"), //Order the columns as you show in your sample #"Reorder Cols" = Table.ReorderColumns(#"Combine Columns", List.FirstN(Table.ColumnNames(#"Changed Type"), 2) & List.Combine(List.Zip({#"Cols to Process",#"New Col Names"}))) in #"Reorder Cols"Custom function: Rename as per code comment
//Rename Query "fnRecordTypes" (fieldNames as list, fieldTypes as list)=> let rowColumnTypes = List.Transform(fieldTypes, (t) => [Type = t, Optional = false]), rowType = Type.ForRecord(Record.FromList(rowColumnTypes, fieldNames),false) in rowTypeThis results in the same output as my previous answer. Note that if you create the chart in Power BI desktop, you can easily sort the X-axis labels , even though your data is not.
