Need help for Paging power query based on offset and limit
I am using below url for table count which can give table limit:
https://xxx.com/api/now/v1/stats/u_tap_request?sysparm_count=true
and using below url to fetch the data:
where we can put sysparm_offset=1 and sysparm_limit=100 - these 2 parameter for offset and limit value.
Now I have made 1 function to dynamically set the offset value:
(Offset as number) as table =>
Source = Json.Document(Web.Contents("https://xxx.com/api/now/table/u_tap_request?sysparm_display_value=false&sysparm_exclude_reference_link=true&sysparm_offset=" & Number.ToText(Offset) & "&sysparm_limit=100")),
#"Converted to Table" = Record.ToTable(Source),
#"Expanded Value" = Table.ExpandListColumn(#"Converted to Table", "Value"),
#"Expanded Value1" = Table.ExpandRecordColumn(#"Expanded Value", "Value", {"parent", "u_solution_complexity_date_time"}),
#"Removed Columns" = Table.RemoveColumns(#"Expanded Value1",{"Name"})
#"Removed Columns"
now i want to load the whole table dynamically with each iteration 100 rows and have to make a table. So how can achieve that?
- Greg_Deckler
I know ImkeF has done this sort of thing.- AnonymousNot applicable
I am really stuck here and dont know the code or logic how to iterate the table dynamically based on the total records. Please help me on that.
- ImkeF
Hi Anonymous ,
please check this sample query. It should give you some ideas how to tackle your task:
let Source = List.Generate( ()=> [Result = Json.Document(Web.Contents("https://pokeapi.co/api/v2/ability/")), Counter=0, Next = Json.Document(Web.Contents("https://pokeapi.co/api/v2/ability/"))[next]], each [Next] <> null, each [ Next = [Result][next], Result = let next = [Result][next], offset = Text.BetweenDelimiters( next, "offset=", "&"), limit = Text.AfterDelimiter(next, "limit="), StartWithEmptyTable = Json.Document(Web.Contents("https://pokeapi.co/api/v2/ability/?offset=0&limit=20", [Query=[offset=Text.From(offset), limit=Text.From(limit)]])) in StartWithEmptyTable, Counter = [Counter] + 1 ] ), #"Converted to Table" = Table.FromList(Source, Splitter.SplitByNothing(), null, null, ExtraValues.Error), #"Expanded Column1" = Table.ExpandRecordColumn(#"Converted to Table", "Column1", {"Result", "Counter"}, {"Result", "Counter"}), #"Expanded Result" = Table.ExpandRecordColumn(#"Expanded Column1", "Result", {"count", "next", "previous", "results"}, {"count", "next", "previous", "results"}), #"Expanded results" = Table.ExpandListColumn(#"Expanded Result", "results"), #"Expanded results1" = Table.ExpandRecordColumn(#"Expanded results", "results", {"name", "url"}, {"name", "url"}) in #"Expanded results1"
