Need help for Paging power query based on offset and limit
I am really stuck here and dont know the code or logic how to iterate the table dynamically based on the total records. Please help me on that.
- ImkeF6 years ago
Hi Anonymous ,
please check this sample query. It should give you some ideas how to tackle your task:
let Source = List.Generate( ()=> [Result = Json.Document(Web.Contents("https://pokeapi.co/api/v2/ability/")), Counter=0, Next = Json.Document(Web.Contents("https://pokeapi.co/api/v2/ability/"))[next]], each [Next] <> null, each [ Next = [Result][next], Result = let next = [Result][next], offset = Text.BetweenDelimiters( next, "offset=", "&"), limit = Text.AfterDelimiter(next, "limit="), StartWithEmptyTable = Json.Document(Web.Contents("https://pokeapi.co/api/v2/ability/?offset=0&limit=20", [Query=[offset=Text.From(offset), limit=Text.From(limit)]])) in StartWithEmptyTable, Counter = [Counter] + 1 ] ), #"Converted to Table" = Table.FromList(Source, Splitter.SplitByNothing(), null, null, ExtraValues.Error), #"Expanded Column1" = Table.ExpandRecordColumn(#"Converted to Table", "Column1", {"Result", "Counter"}, {"Result", "Counter"}), #"Expanded Result" = Table.ExpandRecordColumn(#"Expanded Column1", "Result", {"count", "next", "previous", "results"}, {"count", "next", "previous", "results"}), #"Expanded results" = Table.ExpandListColumn(#"Expanded Result", "results"), #"Expanded results1" = Table.ExpandRecordColumn(#"Expanded results", "results", {"name", "url"}, {"name", "url"}) in #"Expanded results1"- Anonymous6 years agoNot applicable
I have written the below code:
in getData function as below:
= (Offset as number) as table =>
Source = Json.Document(Web.Contents("https://amerisourcebergentest.service-now.com/api/now/table/u_tap_request?sysparm_display_value=false&sysparm_exclude_reference_link=true&sysparm_offset=" & Number.ToText(Offset) & "&sysparm_limit=99")),
#"Converted to Table" = Record.ToTable(Source),
#"Expanded Value" = Table.ExpandListColumn(#"Converted to Table", "Value"),
#"Expanded Value1" = Table.ExpandRecordColumn(#"Expanded Value", "Value", {"parent", "u_solution_complexity_date_time", "u_supplier_name", "watch_list", "upon_reject", "requested_for", "sys_updated_on", "approval_history" }, {"Value.parent", "Value.u_solution_complexity_date_time", "Value.u_supplier_name", "Value.watch_list", "Value.upon_reject", "Value.requested_for", "Value.sys_updated_on", "Value.approval_history", "Value.skills", "Value.number", "Value.u_solution_compllexity_not_required", "Value.state", "Value.u_approved_funding_confirmed_by_finance", "Value.sys_created_by"}),
#"Removed Columns" = Table.RemoveColumns(#"Expanded Value1",{"Name"})
#"Removed Columns"But when I execute the below code it gives me error and it seems to me that it is doing extra looping :
error message:
Source = List.Generate(()=>
[Result = try getData(1) otherwise null, Page=1],
each [Result] <> null,
each [Result = try getData([Page]+99) otherwise null, Page=[Page]+99],
each [result]
Source- ImkeF6 years ago
Hi Anonymous ,
this doesn't look like an error message to me.
