Moses_Lau
Need help cleaning up a column and grouping it.
Hello all,
 The current data set I am working on has a column with such values.
1, 1 - 2, 4, 5 days, 9 days, 9-10 days etc etc.
It keeps on going until 50 ish days.
Is there a way to clean it up and group it down to a range of 5 days, eg 1-5, 6-10, 11-15, 16-20 and so on.
Your help is greatly appreciated!
Hi @Moses_Lau ,
Are there records distributed on either side of a multiple of 5? For example 13-17, 21-31. If so, how are they being considered for distribution?
Does the actual data look like this and not contain 'days' or other text?
Please try adding a custom column like:
a = Number.IntegerDivide(Number.From(Text.Start([Column1],1)),5)*5+1,
b = Text.From(a)&"-"&Text.From(a+4)
b
Gao
Community Support Team
If there is any post helps, then please consider Accept it as the solution  to help the other members find it more quickly.
If I misunderstand your needs or you still have problems on it, please feel free to let us know. Thanks a lot!
How to get your questions answered quickly --  How to provide sample data in the Power BI Forum
Hi @Moses_Lau ,
b
Gao
Yes, Column By Example can handle this (although, you will need to provide a LOT of examples to make it work)
