Moses_Lau's avatar
Moses_Lau
3 years ago
Need help cleaning up a column and grouping it.
Hello all,    The current data set I am working on has a column with such values. 1, 1 - 2, 4, 5 days, 9 days, 9-10 days etc etc.   It keeps on going until 50 ish days.   Is there a way to cle...
    3 years ago
    Hi Moses_Lau ,
    Are there records distributed on either side of a multiple of 5? For example 13-17, 21-31. If so, how are they being considered for distribution?
    Does the actual data look like this and not contain 'days' or other text?
    Please try adding a custom column like:
    a = Number.IntegerDivide(Number.From(Text.Start([Column1],1)),5)*5+1,
    b = Text.From(a)&"-"&Text.From(a+4)
    b
    Gao
    Community Support Team
    If there is any post helps, then please consider Accept it as the solution  to help the other members find it more quickly.
    If I misunderstand your needs or you still have problems on it, please feel free to let us know. Thanks a lot!
    How to get your questions answered quickly --  How to provide sample data in the Power BI Forum
