Need Help: Calculating nearest location distance and location ID
Shailesh2thakur distance is in km. To switch to miles change Earth radius parameter in code accordingly.
let sites = your_SiteMaster_table, vehicles = your_Parking_table, // add geo record into vehicles table v_geo = Table.AddColumn(vehicles, "geo", each GeographyPoint.From(Number.From([long]), Number.From([lat]))), // transform sites table into list of records with geo coordinates sg = List.Buffer( Table.ToList( sites, (x) => GeographyPoint.From(Number.From(x{2}), Number.From(x{1})) & [site = x{0}] ) ), // distance calculation function distance = (parking) => (site) => [r = 6371, // this is Earth radius in km. Change to miles if you like p = Number.PI / 180, a = 0.5 - Number.Cos( (site[Latitude] - parking[Latitude]) * p) / 2 + Number.Cos(parking[Latitude] * p) * Number.Cos(site[Latitude] * p) * (1 - Number.Cos( (site[Longitude] - parking[Longitude]) * p)) / 2, d = 2 * r * Number.Asin(Number.Sqrt(a))][d], // this function finds closest site and distance to it closest = (v) => [f = distance(v), m = List.Min(sg, null, f), dist = m & [distance = distance(v)(m)]][dist], // now we apply closest function to "geo" column with locations find_closest_sites = Table.TransformColumns(v_geo, {"geo", (x) => closest(x)}), // and finally expand site ID and distance to it expand_site_info = Table.ExpandRecordColumn(find_closest_sites, "geo", {"site", "distance"}) in expand_site_info
- AnonymousNot applicable
Can you provide some sample data and the output you want so that can provide more suggestion for you.
Best Regards!
Yolo Zhu
- Shailesh2thakurFrequent Visitor
The Parking Table is as follows:
VehicleNo Start time End time lat long
ALD UP72AT-5281 2024-01-17 03:35:28 2024-01-17 06:46:51 25.449985 81.725858
ALD UP72AT-5281 2024-01-17 06:59:06 2024-01-17 07:06:50 25.443323 81.800569
ALD UP72AT-5281 2024-01-17 07:35:43 2024-01-17 08:14:55 25.526458 81.871894
ALD UP72AT-5281 2024-01-17 08:42:48 2024-01-17 08:58:36 25.589825 81.924649
ALD UP72AT-5281 2024-01-17 09:17:32 2024-01-17 09:53:28 25.626707 81.97712The SiteMaster Table is as under
SiteID Lat Long
Site 01 25.383 81.859
Site 02 29.344 81.897
Site 03 25.358 81.863
Site 04 25.350 81.870
Site 05 25.376 81.869
Site 06 25.342 81.883
Site 07 25.378 81.867
Site 08 25.527 81.853What I need is nearest Site ID & its distance in Parking table w.r.t. each lat/long pair to be added in new columns in a transformed table.
- AlienSx
Thanks a Ton AlienSx
