jaryszek
1 year agoMeasuring power query outside power bi
Hi Guys,
from engineering point of view -> it is possible to measure power queries times outside power bi?
Like run them outside power bi ?
How?
I know diagnostics tool inside power bi but i want to have possibility to control power queries outside power bi?
Best Wishes,
Jacek
Best Wishes,
Jacek
Hi jaryszek , Yes, it’s possible to run Power Query transformations and measure their execution times outside of Power BI Please try these out
- Dataflows: Use Power BI Dataflows and check refresh history for timings.
- Power Query SDK: Run M scripts via Visual Studio with the Power Query SDK.
- Azure Tools: Convert M code to run in Azure Data Factory or Synapse for detailed monitoring.
If this post helped you please do give a kudos and accept this as a solution
Thanks In Advance
- Akash_Varuna
Thanks In Advance
- jaryszek
Do you know if it is possible to import power queries from visual code SDK into Power BI?
Best,
Jacek
