benjamin_sasin's avatar
benjamin_sasin
Icon for Resolver I rankResolver I
6 years ago
Max of Column in Power Query
I'm trying to get the maximum value from colum in a table on Power Query (not Power BI) and I just can't seem to be able to do it:
  • List.Max([column]) won't work.
  • List.Max({[column]}) returns the value of that colum on a row.
  • List.Max(Table.Column(Table, [Column])) won't work due to cyclic reference.
  • Table.Max(Table, Column) like the above will have a cyclic referene.
What's the trick here? Please help.
  • Hi benjamin_sasin ,
    What type of data are you trying to get the max value ?
    Sometimes you have to refer to the table before, like:
    List.Max(PreviousStepName[Column])
    Ricardo
