APQueiroz's avatar
APQueiroz
2 years ago
Joing tables with conditions using Power Query is not working as it should.
Hello, experts! I hope you can help me with this issue. Please excuse any language mistakes.
I am working with two tables in Power Query. The first table contains assignment activity data for equipment, with around 80,000 rows. The second table holds telemetric data for the same equipment, with over 3 million rows.
Assignment data example
equipment_id(Int64)start_date(Datetime)end_date(DateTime)assignment_id(Int64)
1412312342024-10-01 00:002024-10-01 01:0034453
3574633452024-10-01 01:002024-10-01 01:4023423
3171345232024-10-01 01:402024-10-01 03:0062342
Telemetric data example
equipment_id(Int64)timestamp(Datetime)speed
3574633452024-10-01 00:0510
3574633452024-10-01 00:108.2
3171345232024-10-01 00:155.6
My goal is to match each telemetric record with its corresponding assignment_id based on the timestamp interval, allowing me to establish a 1:n relationship between the two tables and calculate the necessary measures.
Here’s my current approach. I created a calculated column as follows:
    AddReferenceColumn =
      Table.AddColumn(
        telemetric_data,
        "assignment_id",
        (row) =>
            search =
              Table.SelectRows(
                assignment_data,
                each ([equipment_id] = row[equipment_id]
                    and [start_date] <= row[timestamp]
                    and [end_date] >= row[timestamp])
            if Table.RowCount(search) > 0 then search{0}[assignment_id] else null
    AddReferenceColumn
This solution works as expected on a sample of 1,000 rows, taking around 4 minutes to load the preview. However, when I attempt to load the full dataset, it becomes extremely slow and never completes.
I then tried a different approach:
    Source = Table.Join(telemetric_data, "equipment_id", assignment_data, "equipment_id"),
    FilterRows = Table.SelectRows(Source, each [timestamp] >= [start_date] and [timestamp] < [end_date])
    FilterRows
This also worked but still failed to load the entire dataset.
What would be the best way to solve this problem?
  • give this a try
        assignment = Table.FromList(
            List.Combine(
                Table.ToList(
                    assignment_data,
                    (x) => {{x{0}, x{1}, -1, x{3}}} & {{x{0}, x{2}, 100, "none"}} // speeds -1 and 100 are for sorting
            (x) => x,
            Table.ColumnNames(telemetric_data) & {"assignment_id"}
        combine_sort = Table.Sort(telemetric_data & assignment, {"equipment_id(Int64)", "timestamp(Datetime)", "speed"}),
        fd = Table.FillDown(combine_sort, {"assignment_id"}),
        filter = Table.SelectRows(fd, (x) => x[speed] <> -1 and x[speed] <> 100)
        filter
    Idea is to combine tables, sort them and fill down assignment_id.
  • Use Table.Buffer as bellow to improve the execution time of your and also make the filtering condition simple code.
    X=Table.Buffer(assignment_data),
          Table.AddColumn(
            telemetric_data,
            "assignment_id",
            (row) =>
                  Table.First(Table.SelectRows(
                    X,
        AddReferenceColumn
    if all the column of table assignment_id are not requiered, beffor using it into Table.Buffer, remove the extra column to save more place for the memory.
    If this answer helped resolve your issue, please consider marking it as the accepted answer. And if you found my response helpful, I'd appreciate it if you could give me kudos. Thank you!
    • APQueiroz's avatar
      APQueiroz
      Unfortunately, it didn't work. The speed of loading is at most 9 rows/s, even when buffering the two tables. I'm loading the data from a Dataflow.
  • give this a try
            List.Combine(
                Table.ToList(
                    assignment_data,
            (x) => x,
        filter
      APQueiroz
      Thank you greatly, AlienSx . That solved my problem—ingenious! It never crossed my mind to use lists like that in Power Query; I thought it would be slower than using tables. It’s perfect for custom unpivot and merging large timeline tables! The only issue is that the column used for sorting cannot contain null values. In my case, I replaced the nulls with a value between the minimum and maximum values.
