APQueiroz
1 year agoFrequent Visitor
Joing tables with conditions using Power Query is not working as it should.
Hello, experts! I hope you can help me with this issue. Please excuse any language mistakes. I am working with two tables in Power Query. The first table contains assignment activity data f...
- 1 year ago
give this a try
let assignment = Table.FromList( List.Combine( Table.ToList( assignment_data, (x) => {{x{0}, x{1}, -1, x{3}}} & {{x{0}, x{2}, 100, "none"}} // speeds -1 and 100 are for sorting ) ), (x) => x, Table.ColumnNames(telemetric_data) & {"assignment_id"} ), combine_sort = Table.Sort(telemetric_data & assignment, {"equipment_id(Int64)", "timestamp(Datetime)", "speed"}), fd = Table.FillDown(combine_sort, {"assignment_id"}), filter = Table.SelectRows(fd, (x) => x[speed] <> -1 and x[speed] <> 100) in filterIdea is to combine tables, sort them and fill down assignment_id.
AlienSx
1 year agogive this a try
List.Combine(
Table.ToList(
assignment_data,
(x) => x,
filter
- APQueiroz1 year agoFrequent Visitor
Thank you greatly, AlienSx . That solved my problem—ingenious! It never crossed my mind to use lists like that in Power Query; I thought it would be slower than using tables. It’s perfect for custom unpivot and merging large timeline tables! The only issue is that the column used for sorting cannot contain null values. In my case, I replaced the nulls with a value between the minimum and maximum values.
