8 years agoNot applicable
Issues connecting to sharepoint - Power BI and Excel
Hi, Hoping to get some help with an issue I am facing. I am trying to connect to a sharepoint site through Power Query in excel as I need a conslidated dataset in Excel format. However, I get a m...
7 years agoNot applicable
I have similar problem and I do not have a clue what else I should do ... Please help
there is error message that it’s not possible to authenticate with my credentials…
I need to sign in
I’m already signed in
I need to choose the level to which are the settings supposed to be applied
And then the error message
- alexrobe7 years ago
Advocate III
Hi Michal!
Have you already found a solution for your issue? I'd be glad to hear it, as I am currently in a similar situation where i cannot authenticate and get stuck on a blank https://preview.powerbi.com/views/oauthredirect.html?code=AQABAAIAAACEfexXxjam etc. page...
Thanks!
Hi Michal,
Did you managed to resolve the error in the end? I'm encountering the same error now and still no idea what to do.
