Issue with date extract from text string- Power Query, Power BI
- 3 years ago
Hi Patrykrz ,
Try the following code to get this output:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("hVVRbttGEL3KwO2HrYg0SUmm8hdYloLCdiwQSN3CzccCC2jQDAEa2FlX/eodcoKepTfpSfpml5IToWgBQ6DJ2Zk3b968fXo6C47ZsTriYXASWSh6Jnupg3gOxBLoTgIiJpPXYFUKQkXV0Av7qJ6c56g41yvJC0Imk259TU3VzIpqXjRz6gJbkh+YY8AJ+qxDmNItXtLDGFcXTfW/cU1RzYq6oo04fL3nX1Wd0p0GO+WUQ3ma4fy9kIrEz+ov6DxuL8Y0TdEsCN9Y1AXq1KEHYocnTytBJrcvowhdqzv7NH06AznBmh9YOLXfKXMQR/fqmLyjN23bLvE3W7TL19ZbWv82eGccKTrRnr0koJYiorT0SHqryvQ4IrtCj7T+NlCYvevp+4oU9Y1sVXxh3dsPKACA3lsPO7LZuWBP7KSnjWppiUvq4iuFC7pmQyVM0hbdfaSHm2bZXk8Jlcgzi+s5eHw2YXiPUNSK4oFoihKogFdVos9ZFuADpkTVLQMH04r/+jPq7wiBbN6xe1bfSynOcCHce0vPqbmAYYFZms+XRbN8iwlXmHHclVS385HMq6Ke0+Yj0qHQsHPslZ4V2jyytBIHjI9eIN3eWZVbTaMRcHV5eWAxt5KDA2Y4ZnnhrKATWS6KWUUfT+o9q4nmUBdVSorRJlxCkzsIqSvH4zNT/+onQ2G7NB614UjiKke1RT2jn7txDdVjVjkQWO/Uie5/0apqWiD0OzaBQwAAhNbuStqyihF+yFW1luvFByZE9viUBukCW8LT+KuiaahDWlPDV+EjAlu1HriBKgPL+3WM5N2/JKyhCHQcV0CBHYJfOAwF2nJYQ8yek4RN2Ix2hROpvkc9jMdGcAIkgxhOGUN+VEmOJVqSdJvsAQeQ38ykG8VfF/WSrgGrSPWZd4Bkjx19R/ViPl+MCkA4Ymuzuc7+D/tBjwfSanWy3mKrZN1ZgvXl2jR3XGq4JTTtbMuwoyTSfcCDg12AC/r7jy8pGT2WY6WqaK5o83DTrX68sa8uzwRv6PxRbWfYJsTugiJY8sbUcTBTem+GkX7GdImtyWSrLu1zhtwn/OlolH5g3lPTZsux9LOqNW9ErAK7T/5g4JO1O+19CNl90OWeetvcyeQovLqBKeoLamXRxOjtQikPm5fnievD7MT2GBWc+Udm1VSP49nDMLbbYys2MmNm/UEK+k828CNmtAciKtvg5i22yHxAMI1UNTnfSNDB2bM3HyAZvNSf7MHEPqW3JY4xXQ54BdHruxWY2ogPmowNXHQwu6N1VEvaovUT1Xho3mYCzeArVshrb8oZTLLWC9XZT7KK7Q48wPG4cYwfm8nBBHH3CiRQprv7WHlxtCd1A7rCOk3zRLyipVFcsff1iCoo1GD54F2vaeZ2GRKuwE//AA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Column1 = _t]), // Relevant steps ----> addDateCode = Table.AddColumn( Source, "dateCode", each List.Select( Text.SplitAny( Text.Replace([Column1], "-", "0"), Text.Remove([Column1],{"0".."9"}) ), each Text.Length(_) = 10 and Text.StartsWith(_, "20") ){0} ), addDate = Table.AddColumn( addDateCode, "date", each Date.From( Text.Combine( { Text.End([dateCode], 2), Text.Range([dateCode], 5, 2), Text.Start([dateCode], 4) }, "-" ) ) ) in addDatePete
Hi Patrykrz ,
addDateCode =
Table.AddColumn(
Source,
"dateCode",
each List.Select(
Text.SplitAny(
){0}
addDate =
Table.AddColumn(
addDateCode,
"date",
each Date.From(
Text.Combine(
addDate
Pete
This might be a stupid question, but what part shall I paste into advanced editor to make a connection for this formula to my real live SQL database 😞
Currently it looks like that (original table and server name replaced):
Source = Sql.Databases("SERVERNAMEABC"),
TABLENAME = SOURCE {[Name="TABLENAME"]}[Data],
dbo_XYZ = ESP{[Schema="dbo",Item="XYZ"]}[Data],
#"Merged columns" = Table.CombineColumns(#"Usunięto kolumny",{"AGREEMENT", "SUFFIX"},Combiner.CombineTextByDelimiter("-", QuoteStyle.None),"ID"),
#"Changed type" = Table.TransformColumnTypes(#"Scalono kolumny",{{"EXPIRYDATE", type date}}),
#"Changed type"
I get token error unfortunately when I try to paste the code
- BA_Pete3 years agoSuper User
The full code is just an example so you can see the steps taken in a standalone query.
To implement in your query, just add two new custom columns:
First column - call this 'dateCode'.
You will need to change [Column1] references to match whatever the name of your text column is:
List.Select( Text.SplitAny( Text.Replace([Column1], "-", "0"), Text.Remove([Column1], {"0".."9"}) ), each Text.Length(_) = 10 and Text.StartsWith(_, "20") ){0}Second column:
Date.From( Text.Combine( { Text.End([dateCode], 2), Text.Range([dateCode], 5, 2), Text.Start([dateCode], 4) }, "-" ) )Pete
- Patrykrz3 years agoFrequent Visitor
Thank you Pete and thank you all! 🙂 you saved my day
