thunderbolt_132's avatar
thunderbolt_132
2 years ago
Is Neo4j and Power BI bidirectional flow possible via Power Query or Power Automate?
I apologize in advance if this is off topic. I have a workflow that connects a neo4j database and power BI, and I got multiple pointers that the best way to do that is via power automate or power query, so I am not sure which direction to take.
I have a workflow that would like to use PowerBI for reporting. Upon selecting certain data in an embedded PowerBI viewer, I would like to somehow feed the knowledge to the database which objects I selected in PowerBI viewer, since I have a separate functionality in the database that I would like to process these objects for. Is this possible in some way? I found that writing data back to the database is quite difficult, but that is not the use case I need, I simply need to inform the database which objects I selected in the powerBI dashboard.
1 Reply
  • Dynamic query parameters are only supported for Direct Query data sources.
