Integration Between SharePoint and Power BI using B2B methodology
Anonymous,
Do you use "Embed in SharePoint Online" feature in Power BI Service to integrate report to Sharepoint? And the users are not able to view the integrated report in SharePoint,right? If so, the report is located in "My workspace" or "App workspace"? How do you grant users access to the report in Power BI Service?
Lydia
Yes, I did use the Embed in SharePoint Online then I go into SharePoint and I add an APP and user the PowerBI app template, then I use the url from the Embed in SharePoint link. The problem is that the users cannot see the integrated report in SharePoint. The report just pulsated with the PowerBI logo. It never returns an error.
- Anonymous8 years agoNot applicable
Anonymous,
Do you grant the users access to the report in Power BI Service? If the report exists in APP workspace, you would need to add users as members of the APP workspace.
Lydia
