Import Power Query (connection only) in to Power BI
- Anonymous9 years ago
Hi martinl,
Do you connect to your Excel in Power BI Service or Power BI Desktop? If you use Power BI Desktop, connect to your Excel file via “Get Data->Excel” entry as follows.
And actually, you don’t need to firstly connect to the folder full of spreadsheets use Power Query and then connect to Excel in Power BI Desktop. You can directly connect to the folder using “Get Data->File->Folder” entry in Power BI Desktop, you are able to merge data of theses spreadsheets into one table and create charts in Power BI Desktop.
However, if you connect to Excel in Power BI Service, please connect to it via “Get Data->Files->Local File” entry and then choose “Import Excel data into Power BI”.
Lydia Zhang
Are you using close and apply at the top left.I think you might be still in the query editor.Once yo close and apply you should be able to see your table and stard analysing your data.
