Radhakrushna
4 years agoRegular Visitor
I need help on Power Query editor of Single Column data Splitting in to other columns
Hello Team, I need your help on the below issue. I have data in the one column(Column Name is Main in first image) as First Image. Need the same data as in another columns as like 2nd or 3rd ima...
4 years agoNot applicable
You can use sort hierarchy, first sort by column C ascending, later by D ascencing and E ascending.
In PQ editor barely visible numbers will appear to insicate sort hierarhy.
- Radhakrushna4 years agoRegular Visitor
Hello Team,
I need the solution as given below image from Main column(Which is rounded with Red colour) of first image.
Krishna
