I Need a help Running total in power query
Please I need calculate column acumulative values. (Running t) in base the column (ve) with the variables (Est) and (CICL)
in the example .
PD = I need Mcode
thanks for your help
- Anonymous5 years ago
Copy paste the below code or just open the pbix to check the applied steps.
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WKlTSUUoEYkMDpVgdBBeVZ4xPEsJLxsozwSdpik0yBdVKGNcMlYuNB3JPEgbPBJVrhE1tMqraZKyS5hiSsQA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Est = _t, CICL = _t, ve = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Est", type text}, {"CICL", type text}, {"ve", Int64.Type}}), #"Added Index" = Table.AddIndexColumn(#"Changed Type", "Index", 1, 1, Int64.Type), BufferedTable = Table.Buffer(#"Added Index"), RunningTotal = Table.AddColumn(BufferedTable, "Running Total", (OutTable) => List.Sum(Table.SelectRows(BufferedTable, (InTable) => InTable[Index] <= OutTable[Index] and InTable[Est] = OutTable[Est] and InTable[CICL] = OutTable[CICL])[ve])) in RunningTotalPaul Zheng _ Community Support Team
- JcarofiFrequent Visitor
In none of the links is the ejm that is needed. The groups that are accumulating are in the same column, I want to group in 2 different columns- jennratten
In the sample image in the original post, it looks like you have created a running total, shaded in yellow, of the data in ve and grouped by the values in Est. Are you also trying to create a second column with running totals for the data in ve and grouped by the values in CICL?
- AnonymousNot applicable
