I have to columns where i need to do comparison. If data in 2 columns are exactly same I am getting correct result but where there are additinal characters, I am not getting desired result. For eg: Following values in 2 columns must match, how to do that? I used contain function in power query, SEARCH function in DAX but not getting result. Need help!!
| abc234def | qazwsxabc234de |
| 4edcv | 234edcv |
| 123qaz | 3qaz |
Hi @Vishal
You can put the following code to advanced editor in power query
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WSkxKNjI2SUlNU9JRKkysKi+ugIkoxepEK5mkpiSXAaWAImAWSMzQyBioEigIpmJjAQ==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Column1 = _t, Column2 = _t]),
#"Changed Type" = Table.TransformColumnTypes(Source,{{"Column1", type text}, {"Column2", type text}}),
#"Added Custom" = Table.AddColumn(#"Changed Type", "Custom", each Text.Combine(List.Intersect({Text.ToList([Column1]),Text.ToList([Column2])}))),
#"Added Custom1" = Table.AddColumn(#"Added Custom", "Custom.1", each if [Custom]<>null then "Matched" else "Not Matched")
#"Added Custom1"
Output
Best Regards!
Yolo Zhu
Hi @Vishal
You can do:
= Table.AddColumn(#"PreviousStepName", "IsContained", each Text.Contains( [Column1] , [Column2] , Comparer.OrdinalIgnoreCase ) or Text.Contains( [Column2] , [Column1] , Comparer.OrdinalIgnoreCase ) , type logical)
Hi @mlsx4 ,
Thanks for your reply. Like I mentioned, I have already tried mentioned steps and it is not working.
I have tried with your exact example and it is working perfectly.
Have you checked?
Yes, Re-checked. Here is output Table for your reference which is incorrect.
| Col1 | Col2 |
| 2PC920040Y | Not in Report |
| HJ0403QJ | Not in Report |
| QJ05Y5E5 | Not in Report |
| Not in Report | Q0V114HJ0403QJ |
| Not in Report | A0V114QJ05Y5E5 |
| Not in Report | P09W001C0F87WG |
| Not in Report | T0EW00K90D3T2E |
| Not in Report | PC920040Y |
| 1C0F87WG | Not in Report |
| K90D3T2E | Not in Report |
Ideally every single value must show status as Matched.
Hi @Vishal
#"Added Custom1"
Output
Best Regards!
Yolo Zhu
Hi @Vishal
I don't know which is your data then, with the only information you have provided, it works for me...
Try to put here more examples, especially what you're trying to compare and fails...
| 10 | |
| 6 | |
| 5 | |
| 2 |
