Aasozab
2 years agoRegular Visitor
How to swap some values between two columns in power query using either GUI elements or M code?
dufoq3
2 years agoHi, I dind´t provide the code with sample data, but you can create it either in power query vie Enger Data button or in excel and then import to power query.
The purpose was to show sou the way how to achieve expected result. You can use codes above by adding them separately as custom column. Just replace [Column1] with [DOJ] and [Column2] with [Designation]. Don't forget to set column name for first code: "Extracted Date".
