How to summarize columns using Power Query Editor NOT DAX
- Anonymous5 years ago
Hi Anonymous
Ok, it is all about the dates, so let's extract the min and max date in the original data, then generate every single day in between, have a try
let Source = Table.Group(Table.SelectColumns(Pos_Case_DPH_2,{"Preferred MSOA Name", "Specimen Date", "Count"}), {"Preferred MSOA Name", "Specimen Date"}, {{"Count", each List.Sum([Count]), type nullable number}}), Date = List.Transform( { Number.From(List.Min(Source[Specimen Date]))..Number.From(List.Max(Source[Specimen Date]))}, Date.From), MSOA = Table.FromList( List.Distinct(Source[Preferred MSOA Name])), #"Renamed Columns" = Table.RenameColumns(MSOA,{{"Column1", "Preferred MSOA Name"}}), #"Added Custom" = Table.AddColumn(#"Renamed Columns", "Specimen Date", each Date), #"Expanded Date" = Table.ExpandListColumn(#"Added Custom", "Specimen Date"), #"Merged Queries" = Table.NestedJoin(#"Expanded Date", {"Preferred MSOA Name", "Specimen Date"}, Source, {"Preferred MSOA Name", "Specimen Date"}, "Expanded Date", JoinKind.LeftOuter), #"Expanded Expanded Date" = Table.ExpandTableColumn(#"Merged Queries", "Expanded Date", {"Count"}, {"Count"}), #"Replaced Value" = Table.ReplaceValue(#"Expanded Expanded Date",null,"0",Replacer.ReplaceValue,{"Count"}) in #"Replaced Value"
Hi Anonymous
Right click to start a new blank query to paste it in Advanced Editor, let me know if it does not work as I am modifying the code without accessing your source folder...
Source = Table.SelectColumns(Pos_Case_DPH_2,{"Preferred MSOA Name", "Specimen Date", "Count"}),
Date = List.Distinct( Source[Specimen Date]),
#"Replaced Value"
And one suggestion on reading from folder, please do not use Sample query generated by PBI for you, try to add a custom column to combine your files. You can search for it, there are many posts about it.
Hi Anonymous thanks again for your reply.
That has almost worked. I have a slight issue in that the query takes so long to process that it crashes before it finishes. I created a new dashboard and removed all other tables that it references and removed the columns except the count, the date and the MSOA. This then worked up to a point.
A further issue then was that your query did not sum the 'count' column and so I had to use summarizecolumns and use the sum function to do that, ending up with a calculated table again. This then did not create a row for every date from the calendar table. Instead, it created a row for each MSOA where there was a date that had a case. This is OK for now as there are cases every day in at least one MSOA but in time it is likely that there might be a day with no cases at all in any MSOA and so the query would not generate rows that contained 0 counts.
Does that make sense? Thanks again so far, I really appreciated it!
- Anonymous5 years agoNot applicable
Hi Anonymous
Understood, so sum up the Count first, try it
let Source = Table.Group(Table.SelectColumns(Pos_Case_DPH_2,{"Preferred MSOA Name", "Specimen Date", "Count"}), {"Preferred MSOA Name", "Specimen Date"}, {{"Count", each List.Sum([Count]), type nullable number}}), Date = List.Distinct( Source[Specimen Date]), MSOA = Table.FromList( List.Distinct(Source[Preferred MSOA Name])), #"Renamed Columns" = Table.RenameColumns(MSOA,{{"Column1", "Preferred MSOA Name"}}), #"Added Custom" = Table.AddColumn(#"Renamed Columns", "Specimen Date", each Date), #"Expanded Date" = Table.ExpandListColumn(#"Added Custom", "Specimen Date"), #"Merged Queries" = Table.NestedJoin(#"Expanded Date", {"Preferred MSOA Name", "Specimen Date"}, Source, {"Preferred MSOA Name", "Specimen Date"}, "Expanded Date", JoinKind.LeftOuter), #"Expanded Expanded Date" = Table.ExpandTableColumn(#"Merged Queries", "Expanded Date", {"Count"}, {"Count"}), #"Replaced Value" = Table.ReplaceValue(#"Expanded Expanded Date",null,"0",Replacer.ReplaceValue,{"Count"}) in #"Replaced Value"- Anonymous5 years agoNot applicable
Hi Anonymous that has worked to get the count column thank you. The only thing missing is still the lack of rows for every single date. I've taken a snip of the table when sorted in acending order by date. You can see there are rows for the 3rd March 2020 and the 5th March 2020 but the query hasn't generated rows for the 4th March and other dates when there isn't a case in any single MSOA on that date. The 4th March ideally should have 99 rows that have a count of 0. Is that possible? Thanks.
Hi Anonymous
