Help with recursive web power query (oDATA, SuccessFactors)
- 5 years ago
Here is an example on how to do this with List.Generate using a test REST API. I adapted the approach described well in this article. You can paste the code into a blank query to step through it.
List.Generate() and Looping in PowerQuery - Exceed
let fn = (pagenumber) => Json.Document(Web.Contents("https://api.instantwebtools.net/v1/passenger?page=" & pagenumber & "&size=1000")), mylist = List.Generate(()=> [Page = 1, Result = fn(Number.ToText(1))], each List.Count([Result][data])>0, each [Page = [Page] + 1, Result = fn(Number.ToText([Page]+1))]), #"Converted to Table" = Table.FromList(mylist, Splitter.SplitByNothing(), null, null, ExtraValues.Error), #"Expanded Column1" = Table.ExpandRecordColumn(#"Converted to Table", "Column1", {"Page", "Result"}, {"Page", "Result"}), #"Expanded Result" = Table.ExpandRecordColumn(#"Expanded Column1", "Result", {"data"}, {"data"}), #"Expanded data" = Table.ExpandListColumn(#"Expanded Result", "data"), #"Expanded data1" = Table.ExpandRecordColumn(#"Expanded data", "data", {"_id", "name", "trips", "airline", "__v"}, {"_id", "name", "trips", "airline", "__v"}) in #"Expanded data1"Pat
- 5 years ago
Hello Pat, thank you very much for your help!
You inspired me and I was able to contruct my own solution. It seems very easy at the first sight and also works great for my scenario:
This returns a list of lists of records that I can easily expand and work with.
It works great, loads data - but maybe looks too simple when compared with other examples of recursive functions I have been going through.
Could you please have a look at my code if you have any possible concerns about it, because I can't believe this short code actually does tone of work.
Thanks, Jakub!
#"Expanded data1"
Pat
Thanks, Jakub!
- mahoneypat5 years agoMicrosoft Employee
If it works and is performant, that's the real test. Does it make two web calls with each iteration?
Pat
- jdusek925 years agoAdvocate III
How can I test that it does not perform all the calls twice?
Warm regards, Jakub
You could probably tell with the query diagnostics features (or with an external tool like Fiddler); however, if it is performant and you don't have a limit on web calls, don't worry about it.
Pat
- marcosimeone4 years agoFrequent Visitor
hi, can you post the advanced editor for this code. I try to replicate the code but it remains errors
- jdusek924 years agoAdvocate III
since then I improved it, this is the function that I use:
Source = (SFurl as text) => let
Source = List.Generate(()=>Record.AddField(Json.Document(Web.Contents(SFurl))[d],"count",1) , each Record.HasFields(_,"results") =true and (Record.HasFields(_,"count") and _[count]<=99999), each try Record.AddField(Json.Document(Web.Contents(_[__next]))[d],"count",_[count]+1) otherwise [df=[__next="SSS"]] ),
#"Expanded Column1" = Table.ExpandRecordColumn(#"Converted to Table", "Column1", {"results"}, {"results"}),
#"Expanded results" = Table.ExpandListColumn(#"Expanded Column1", "results")
#"Expanded results"
SourceIt will return a table/list of records, that you can further expand as you need.
(it has been a while I used it for the last time, so I cannot explain it, but it works for me - pull oData from SuccessFactors)
the parameter should look like this:
"https://XXXXX/odata/v2/Position?$format=JSON..."
Warm regards,
Jakub
great thanks, i managed to get it to work in Power BI Desktop, but when I publish to power bi serivice it says that the dataset cannot be updated because there is a dynamic datasource as the source is contained in the query. how did you solve it?
here is the error:
Picking up on this - as for our organization - and for security in general - we did not want to use basic authentication against SuccessFactors - I came up with an alternative to the marked solution here.
Firstly I created a seperate dataflow for the token authentication.For that part I use a service account and generate the assertion with the SAML generator supplied from SAP.
For the powerquery for this part it looks like below:
letAuth = Json.Document(Web.Contents(Path, [Headers=[#"Content-Type"="application/x-www-form-urlencoded"],Content=Text.ToBinary(#"insertion"), RelativePath="/oauth/token"])),#"Converted to table" = Record.ToTable(Auth),#"Transform columns" = Table.TransformColumnTypes(#"Converted to table", {{"Value", type text}}),#"Replace errors" = Table.ReplaceErrorValues(#"Transform columns", {{"Value", null}}),#"Transposed table" = Table.Transpose(#"Replace errors"),#"Promoted headers" = Table.PromoteHeaders(#"Transposed table", [PromoteAllScalars = true]),#"Changed column type" = Table.TransformColumnTypes(#"Promoted headers", {{"access_token", type text}, {"token_type", type text}, {"expires_in", Int64.Type}}),#"Added custom" = Table.AddColumn(#"Changed column type", "Token", each [token_type] & " " & [access_token]),Navigation = #"Added custom"[Token],#"Navigation 1" = Navigation{0},#"Convert to table" = Table.FromValue(#"Navigation 1")in#"Convert to table"The insertion part I referenced as a seperate variable.
2nd - for any new Odata sources I want to fetch into PowerBI I setup a seperate dataflow, where I reference the Authentication Token ( this is running 1 a day to get a new token)
For getting the odata - I have this function. For this to work, you should always use inlinecount=allpages in the query.(RelPath as text) =>letToken = Authentication{0}[Value],RelPath = RelPath,initReq = Json.Document(Web.Contents(baseurl, [Headers=[#"Accept"="application/json", Authorization=Token],RelativePath=RelPath]))[d],nextUrl = Text.AfterDelimiter(initReq[__next],"v2/"),initValue= initReq[results],gather=(data as list, url)=>letnewReq=Json.Document(Web.Contents(baseurl,[Headers=[#"Accept"="application/json", Authorization=Token],RelativePath=url]))[d],newNextUrl = Text.AfterDelimiter(newReq[__next],"v2/"),newData= newReq[results],data=List.Combine({data,newData}),Converttotable = Record.ToTable(newReq),Pivot_Columns = Table.Pivot(Converttotable, List.Distinct(Converttotable[Name]), "Name", "Value", List.Count),Column_Names=Table.ColumnNames(Pivot_Columns),Contains_Column=List.Contains(Column_Names,"__next"),check = if Contains_Column = true then @gather(data, newNextUrl) else dataincheck,Converttotable = Record.ToTable(initReq),Pivot_Columns = Table.Pivot(Converttotable, List.Distinct(Converttotable[Name]), "Name", "Value", List.Count),Column_Names=Table.ColumnNames(Pivot_Columns),Contains_Column=List.Contains(Column_Names,"__next"),outputList= if Contains_Column= true then @gather(initValue,nextUrl) else initValue,expand=Table.FromRecords(outputList)inexpand
