Syndicate_Admin's avatar
2 years ago
Help with calculations in Power BI
I need to divide the following columns: I need to divide the blue by the red for all entries. So I will need to do the following
1423.59/4602.72
1423.59/4602.72
989.71/4602.72
2189.42/4602.72
    2 years ago
    Hi Syndicate_Admin
    You can try the following code.
    Measure =
    VAR a =
            SUM ( 'Table'[lons] ),
            FILTER ( ALLSELECTED ( 'Table' ), [Month] IN VALUES ( 'Table'[Month] ) )
        DIVIDE ( SUM ( 'Table'[lons] ), a )
    Best Regards!
    Yolo Zhu
    If this post helps, then please consider Accept it as the solution to help the other members find it more quickly
    Hi Syndicate_Admin
    Measure =
    VAR a =
    Best Regards!
    Yolo Zhu
        Hi Syndicate_Admin
        Best Regards!
        Yolo Zhu
