Syndicate_Admin's avatar
Icon for Administrator rankAdministrator
2 years ago
Help with a reset running total on two criteria
New poster so go gentle with me!
My issue is fairly straight forward but I just don't seem to be able to solve it.
I have 3 columns of data:-
POSplitRows - This is a grouping of data lines based on other criteria not relevant to this issue.
Units - Values attributable to each "POSplitRows" line
Running Total - Running total of "Units" that I would like to reset when two criteria are reached 1. Reset when the "POSplitRows" grouping changes and 2. Reset within each "POSplitRows" grouping if the running total exceeds or equals 5000.
My solution
1. Extracted the columns needed from source data
2. Buffered "Units" & "POSplitRows" as lists
3. Created a custom function with the code below:-
= (values as list) as list =>
GRTList = List.Generate(
()=> [ GRT = values{0}, i = 0 ],
each [i] < List.Count(values),
each try
if [GRT] + values{[i]} <= 5000
then [GRT = [GRT] + values{[i] + 1}, i = [i] + 1]
else [GRT = values{[i] + 1}, i = [i] + 1]
otherwise [i = [i] + 1] ,
each [GRT] )
GRTList
4. Applied this function code to the data at stage 2 using the custom code below:-
= Table.FromColumns(
Source[POSplitRows], Source[Units],
fxRunningUnitGroupx(BufferedUnits, BufferedIndex)
"POSplitRows",
"Units",
"Running Total"
Problem
The split to reset at 5000 units seems to be working as expected (Yellow box below) but the reset based on the "POSplitRows" grouping is performed on the second line of the new "POSplitRows" grouping (Red Box below). I want the "Running Total" column to show the first line of the new grouping as the new running total (ie Start at 404 units, not 287)
I think it is something not quite right in my fuction coding above. If anyone can offer any ideas I would be grateful.
Thanks.
  • amustafa's avatar
    amustafa
    Icon for Solution Sage rankSolution Sage
    Easier to do this in a calulated column using DAX vs. Power Query. Adjust the table name accordingly.
    Running Total =
    VAR CurrentPOSplitRows = 'Sample'[POSplitRows]
    VAR CurrentIndex = 'Sample'[Index]
    VAR RunningTotalSoFar =
        CALCULATE(
            SUM(Sample[Units]),
            FILTER(
                'Sample',
                Sample[POSplitRows] = CurrentPOSplitRows &&
                Sample[Index] <= CurrentIndex
    VAR ResetRunningTotal =
        RunningTotalSoFar -
        CALCULATE(
            SUM(Sample[Units]),
            FILTER(
                Sample,
                Sample[Index] < CurrentIndex &&
                RunningTotalSoFar >= 5000
        IF(
            ResetRunningTotal >= 5000,
            Sample[Units],
            ResetRunningTotal
  • Many thnaks for this.
    I forgot to mention I am using the Power Query engine behind Excel and not Power BI.
    Can I enter the DAX code or can it be adapted for Power Query for Excel?
    Thanks again
    • amustafa's avatar
      amustafa
      I was afraid you gonna say that:-)
      In power query its a matter of creating a function. I'll see what I can do. Stay tuned
      • Syndicate_Admin's avatar
        Many thanks.
        I attempted some code in a function in my original post. It really is just offsetting the POSplitRows by one line as described above. It may just be something I have missed in that code above.
  • amustafa's avatar
    amustafa
    Got it to work 🙂
    Source = Excel.Workbook(File.Contents("C:\Users\aliom\OneDrive - MS365\Power BI Samples\Running Totals with reset\Sample.xlsx"), null, true),
    Table1_Table = Source{[Item="Table1",Kind="Table"]}[Data],
    #"Changed Type" = Table.TransformColumnTypes(Table1_Table,{{"POSplitRows", type text}, {"Units", Int64.Type}}),
    #"Added Index" = Table.AddIndexColumn(#"Changed Type", "Index", 1, 1, Int64.Type),
    // Function to calculate running total with reset logic
    AddRunningTotal = (table as table) as table =>
    RowCount = Table.RowCount(table),
    RunningTotalList = List.Accumulate(List.FirstN(table[Units], RowCount), {},
    (state, current) =>
    LastTotal = if List.Count(state) = 0 then 0 else List.Last(state),
    LastRow = if List.Count(state) = 0 then null else table{List.Count(state)-1},
    LastPOSplitRows = if LastRow = null then "" else LastRow[POSplitRows],
    NewTotal = if LastTotal >= 5000 or (LastRow <> null and LastRow[POSplitRows] <> table{List.Count(state)}[POSplitRows]) then current else LastTotal + current
    state & {NewTotal}
    RunningTotalColumn = Table.FromColumns({table[Index], table[POSplitRows], table[Units], RunningTotalList}, {"Index", "POSplitRows", "Units", "Custom"})
    RunningTotalColumn,
    // Apply function to add Running Total column
    FinalTable = AddRunningTotal(#"Added Index")
    FinalTable
      Hi, many thanks for this.
      My source is a query rather than an excel file. I have remapped the source to the Query within Power Query.
      It is taking a long time to run. Do I need to remap any other elements of the code to the discrete query name of my source within the function part of the coding?
      • amustafa's avatar
        amustafa
        Regardless of the source, you can add an index column to your data and then copy from my code after creating the index step...
        //Your existng code
        AddRunningTotal = (table as table) as table => ....
