Ahmed_Khalil
2 years agoFrequent Visitor
Help to Manage Duplicate Values in Power Query at Power BI
i have the first column and i want a formula or any other way to return the value of Column B to be like below ColumnA ColumnB 1000 1000A 1000 1000B 1000 1000C 1000 1000D 1001...
- 2 years ago
I have written the M-Code for your requirement.
Please find the excel file and you will find the m code with in the query 'Table1'
Need a Power BI Consultation? Hire me on Upwork
Connect on LinkedIn
Did I answer your question? Mark my post as a solution! If I helped you, click on the Thumbs Up to give Kudos.
- 2 years ago
Given:
Using this M Code (which will reproduce the above table:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMjQwMFCK1SHEMMRgGMEYxkqxsQA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [ColumnA = _t]), #"Grouped Rows" = Table.Group(Source, {"ColumnA"}, {{"Count", each Table.RowCount(_), Int64.Type}}), #"Added Custom" = Table.AddColumn(#"Grouped Rows", "add Alpha", each List.FirstN({"A".."Z"},[Count]), type {text}), #"Removed Columns" = Table.RemoveColumns(#"Added Custom",{"Count"}), #"Expanded add Alpha" = Table.ExpandListColumn(#"Removed Columns", "add Alpha"), #"Inserted Merged Column" = Table.AddColumn(#"Expanded add Alpha", "ColumnB", each Text.Combine({[ColumnA], [add Alpha]}, ""), type text), #"Removed Columns1" = Table.RemoveColumns(#"Inserted Merged Column",{"add Alpha"}) in #"Removed Columns1"will return:
ahadkarimi
2 years agoSolution Specialist
= Table.AddColumn(PreviousStepName, "ColumnB", each Text.From([ColumnA]) & Text.From([Index]))
