Anonymous's avatar
2 years ago
Help for operations (Power Query)
Hi everyone, I want to make operations through Power Query. I am a rookie but I almost succeeded reaching my goal here but now I am stuck. I have 5 columns which gives for each technician, type of...
  • dufoq3's avatar
    2 years ago
    Hi Anonymous, I've edited whole query you've provided in pbix file.
    Result
    Source = Excel.Workbook(File.Contents("C:\Users\krifaily\Desktop\timesheet v1\2023\Report_STD_EMPDETAIL_TIMESHEET_2023-11-27.xlsx"), null, true),
    Sheet1_Sheet = Source{[Item="Sheet1",Kind="Sheet"]}[Data],
        RemovedBlankColumns = Table.FromColumns(List.Select(Table.ToColumns(Sheet1_Sheet), each List.Count(List.RemoveNulls(_)) > 0)),
        RemovedBlankRows = Table.SelectRows(RemovedBlankColumns, each not List.IsEmpty(List.RemoveMatchingItems(Record.FieldValues(_), {"", null}))),
        RemovedTopRows = Table.Skip(RemovedBlankRows, each [Column3] <> "Employee Name"),
        PromotedHeaders = Table.PromoteHeaders(RemovedTopRows, [PromoteAllScalars=true]),
        ColumnNamesUpdated = List.Transform(Table.ColumnNames(PromotedHeaders), each if Text.StartsWith(_, "Column") then try Text.Replace(_, _, Table.Column(PromotedHeaders, _){0}?) otherwise _ else _),
        RenamedColumns = Table.RenameColumns(PromotedHeaders, List.Zip({ Table.ColumnNames(PromotedHeaders), ColumnNamesUpdated })),
        RemovedTopRows2 = Table.Skip(RenamedColumns, each [Employee Name] = null),
        RemovedOtherColumns = Table.SelectColumns(RemovedTopRows2,{"Employee Name", "Pay Code", "Work Date", "Hours"}),
        FilledDown = Table.FillDown(RemovedOtherColumns,{"Employee Name"}),
        FilteredRows = Table.SelectRows(FilledDown, each ([Pay Code] <> null and [Pay Code] <> "Meal")),
        ChangedType = Table.TransformColumnTypes(FilteredRows,{{"Employee Name", type text}, {"Pay Code", type text}, {"Work Date", type date}, {"Hours", type number}}),
        GroupedRows = Table.Group(ChangedType, {"Employee Name", "Pay Code", "Work Date"}, {{"Hours", each List.Sum([Hours]), type nullable number}}),
        Ad_PayCodeHelper = Table.AddColumn(GroupedRows, "Pay Code Helper", each if Text.StartsWith([Pay Code], "Holiday", Comparer.OrdinalIgnoreCase) then "Holiday" else [Pay Code], type text),
        GroupedRows2 = Table.Group(Ad_PayCodeHelper, {"Employee Name", "Work Date", "Pay Code Helper"}, {{"Hours", each
            [ a = Table.SelectRows(_, (x)=> Text.Contains(x[Pay Code], "Worked", Comparer.OrdinalIgnoreCase)),     //Holiday Worked Hours
              b = Table.SelectRows(_, (x)=> not Text.Contains(x[Pay Code], "Worked", Comparer.OrdinalIgnoreCase)), //Holiday Shift Hours
              c = try if a[Hours]{0}? >= b[Hours]{0}? then Record.SelectFields(a{0}, {"Pay Code", "Hours"}) else [Pay Code = b[Pay Code]{0}, Hours = b[Hours]{0}?-a[Hours]{0}?] otherwise [Pay Code = [Pay Code]{0}, Hours = List.Sum([Hours])]
            ][c], type record}}),
        RemovedColumns = Table.RemoveColumns(GroupedRows2,{"Pay Code Helper"}),
        ExpandedRecord = Table.ExpandRecordColumn(RemovedColumns, "Hours", {"Pay Code", "Hours"}),
        Ad_WeekOfYear = Table.AddColumn(ExpandedRecord, "Week of Year", each Date.WeekOfYear([Work Date], Day.Monday), Int64.Type)
        Ad_WeekOfYear
