Hello everyone, I need an help Regarding Power Query/Dax in Power BI
Sorry--copy/paste error:
OpenOrderSales = CALCULATE(SUM([OpenOrderSalesAUD]), DISTINCT('MCS_POWERBI_FACT'[DocDueDate]), USERELATIONSHIP('MCS_POWERBI_FACT'[DocDueDate],'Master Calendar'[Date]))
- Sai_Kumar5 years agoFrequent Visitor
I tried it - But, the measure output was the same as my last measure as mentioned in the post.
If you see the Doc_Date and Doc_Due_Date columns
The requirement was, we need to extract only Doc_Due_date if Doc_Due_date was in the Current month.The OLD_Open Order Sales measure was working but giving us all open order Sales - where we need only present and future months open order sales.
- v-yingjl5 years ago
Hi Sai_Kumar ,
Consider using Crossfilter() to change the cross filter direction or change it manually in the relationship view to check whether it works.
Plesae refer: Bi-directional relationship guidance
If it still has the same issue, you can consider sharing a simple sample file without any sentive information for further discussion.
