[HELP!] Identify top 3 values summed based on another column
Hi all
I have a data table containing of the first 2 columns as below want to create a column chart showing: The top 3 CCY with highest lump sum amount while the remaining CCYs are accummulated under 1 column named "Others". My solution is to create the third column named Top_3_CCY with below code and use it as axis labels and legend for my chart.
| CCY | Amount_in_USD | Top_3_CCY (desired) | Top_3_CCY (actual) |
| USD | 10031 | USD | USD |
| USD | 120 | USD | USD |
| JPY | 3440 | JPY | Others |
| EUR | 534 | Others | Others |
| GBP | 1297 | Others | Others |
| KRW | 30000 | KRW | KRW |
1. Is there any better solution to the original problem?
2. If yes, what should I amend in the code to get the desired outcome?
Thank you so much in advance!
Hi birdietran ,
Try this:
Top_3_CCY = IF ( RANKX ( 'Outward Overseas', CALCULATE ( SUM ( 'Outward Overseas'[Txn Amount in USD] ), ALLEXCEPT ( 'Outward Overseas', 'Outward Overseas'[CCY] ) ), , DESC, DENSE ) <= 3, 'Outward Overseas'[CCY], "Others" )Best regards
Icey
If this post helps, then consider Accepting it as the solution to help other members find it faster.
- Icey
Hi birdietran ,
Try this:
Icey
- birdietranFrequent Visitor
This is exactly what I need! Thank you so much!
- PC2790
Try this if it works:
Top3 = SumX(TOPN(3,SUMMARIZE('Outward Overseas','Outward Overseas'[CCY],"ColumnName",[Txn Amount in USD]),[ColumnName],DESC),[Txn Amount in USD])
Hi
Thank you for your help. It didnt work though. I tried add a Top3 column and below is what I got :< :
Hi
Anyone can help please :<?
