Ahmed_Khalil
2 years agoFrequent Visitor
Extract the data from table visual in power bi using power automate [100K limits ]
i have power bi report and in the canvas there is a table visual and some slicers, what i need is to create a flow that when user make some filteration based on slicers then extract the data from the...
rubayatyasmin
2 years agoHi, Ahmed_Khalil
you can follow this article on how to use Power Automate to export data.
Export Power BI data to CSV via Power Automate visual and upload to SharePoint - CloudFronts
If you want to use power automate then you will have to cinsider the limitation.
also, found these articles that may be of help.
Solved: export data from power bi visuals to excel automat... - Microsoft Fabric Community
Power Automate Export is limited 1000 Rows - Issue - Power Platform Community (microsoft.com)
Solved: Re: Power Automate - Export Button - Microsoft Fabric Community
