GeekAlfPro's avatar
GeekAlfPro
Icon for Helper V rankHelper V
5 years ago
Export entire m code from Power BI to power Query in Excel
i have some M Code in PBI Desktop, and i'd like to import this code in Power Query in Excel.
i installed power query helper, see here but the app changed completly and i don't manage to do it.
is there a way to do this easily ?
  • Hi GeekAlfPro
    Sure you can just copy the queries as usual, with Ctrl-C, on the queries pane (on the left) in the query editor in Power BI and then open Power Query in Excel and paste, Ctrl-V, on the same queries pane (on the left).  That should get you all your queries moved.
    Please mark the question solved when done and consider giving a thumbs up if posts are helpful.
    Cheers
  • AlB's avatar
    AlB
    Hi GeekAlfPro
    Cheers
    • GeekAlfPro's avatar
      GeekAlfPro
      Hi AlB
      that's it !
      it didn't work cause i tried to paste it in the query editor not in the pane !
      thanks
