Register now!To celebrate FabCon Vienna, we are offering 50% off select exams. Ends October 3rd. Request your discount now.
Hello All,
I have imported a csv file data from sharepoint folder to dataverse table two days back using dataflow in dataverse. it was succesfull. but if I see the data flow now, it show invalid credentials.
I tried following steps to solve:-
1. Try to create new dataflow. BUt my step stop at navigation. It connected to data source and failed to import file.
2. Re-signin with my credentials.
3.checked the path of sharepoint datasource.
But no of them worked.
why is it so ?Please help to solve this issue.
Hi @Krishna09 ,
There is an same issue and the issue has been submitted to ICM (338416793) . I'll be back with an update if there's any progress .
Gao
Community Support Team
If there is any post helps, then please consider Accept it as the solution to help the other members find it more quickly. If I misunderstand your needs or you still have problems on it, please feel free to let us know. Thanks a lot!
How to get your questions answered quickly -- How to provide sample data
Also having issues with dataflows where Sharepoint folder is a data source. Existing programmed dataflows working intermittently. Ability to create new dataflows also intermittently available.
Hi @Anonymous ,
Thank you very much. but in mean time how are you able to manage to import? I tried to create new dataflow, but its ending at navigation step.
Hi @Krishna09 ,
Gao
