Krishna09
3 years agoHelper III
Data flow data importing issue and dataflow stops at navigation step
Hello All, I have imported a csv file data from sharepoint folder to dataverse table two days back using dataflow in dataverse. it was succesfull. but if I see the data flow now, it show invalid cre...
- Anonymous3 years ago
Hi Krishna09 ,
There is an same issue and the issue has been submitted to ICM (338416793) . I'll be back with an update if there's any progress .Best Regards,
Gao
Community Support TeamIf there is any post helps, then please consider Accept it as the solution to help the other members find it more quickly. If I misunderstand your needs or you still have problems on it, please feel free to let us know. Thanks a lot!
How to get your questions answered quickly -- How to provide sample data
Krishna09
Hi Anonymous ,
Thank you very much. but in mean time how are you able to manage to import? I tried to create new dataflow, but its ending at navigation step.
